This USB to fiber optic converter lets you utilize the USB 2.0 port on your laptop or tablet to provide a secure fiber network connection.
Secure connectivity
For reliable fiber connectivity, this converter protects your network from problems with electronic interference. -
Easy portability
Compact and portable, this converter is powered directly from the USB port, making it easy to connect when you're on the go.
- StarTech.com USB to Fiber Optic Converter, 100Mbps, USB 2.0 to Fiber Network Adapter, 100BASE-FX SC Female Duplex Multimode Fiber/MMF Compatible, 2Km, Compact USB to Fiber LAN Adapter - USB to LAN Adapter (US100A20FXSC) - network adapter - USB 2.0 - 100Base-FX/100Base-SC x 1
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Ports
- 5.5 cm x 26 cm x 2 cm
- 100 g
- Cabling Type
- Ethernet 100Base-FX, Ethernet 100Base-SC
- Data Link Protocol
- 100Mb LAN
- Max Transfer Distance
- 2 km
- Data Transfer Rate
- 100 Mbps
- Processor
- ASIX AX88772C
- IEEE 802.1Q, IEEE 802.3x
- Black
- System Requirements
- Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 3.5 to 4.11.x LTS versions
- 2-year warranty
- Network adapter
- Form Factor
- External
- USB 2.0
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- Fast Ethernet
- 100 Mbps
- 2 km
- Optical Wave Length
- 1310 nm
- Status Indicators
- Power, link/activity
- WOL, USB powered
Processor / Memory
- Processor
- ASIX AX88772C
- 1 x 100Base-FX/100Base-SC - SC - female - x 2
- Plug and Play, FCC, RoHS
- Black
- OS Required
- 5.5 cm
- 26 cm
- 2 cm
- 100 g
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 5 - 90%
StarTech.com 3m Multimode 62.5/125 Duplex Fiber Patch Cable LC - SC | In Stock | £15.85 |
StarTech.com 10/100 Mbps Multi Mode Fiber Media Converter SC 2 km | In Stock | £69.74 |
StarTech.com USB 2.0 to Fiber Converter | In Stock | £130.54 |
StarTech.com USB C to Fiber Optic Converter | In Stock | £180.63 |
