StarTech.com Unmanaged 2.5G Switch - 5 port
Quicklinx: GPJNWS00 Mfr#: DS52000
Type: 2.5 Gigabit Ethernet
Ports: 5
Data Transfer Rate: [N/A]
Managed: No
POE: No
Hurry, only 3 left in stock!
£104.27 ex VAT
£125.12 inc VAT
The unmanaged network switch offers five multi-speed Ethernet ports (10/100/1000/2500 Mbps) in a compact and durable all-metal casing while remaining silent and energy-efficient (IEEE 802.3az). The network switch is the ideal solution to dramatically speed up your network to support 2.5GBASE-T, and being an unmanaged switch, you can set it up in no time.
  • Enhance your network
    This network switch allows you to use existing Cat5e/Cat6/Cat6a cabling to increase the bandwidth to 2.5 Gbps, ideal for large file transfers, streaming, network sharing/storage, or other bandwidth-intensive applications. Auto-negotiation detects the highest supported speeds on your devices for maximum performance and compatibility. You can also use it in combination with Wi-Fi 6 (802.11ax) wireless access points to expand your network range, bandwidth, and accessibility.
  • Secure and versatile
    The 2.5G switch offers a security K-slot for more permanent and secure setups (cable not included). The unintrusive design and small dimensions (6.1x4.7x1.1 inch / 155x120x30 mm) make it easily adaptable to any deployment and has clear diagnostic LEDs that show the status of the devices at a glance. Additional features such as 9K jumbo frames, full-duplex, 16K MAC address table, QoS IEEE 802.1p, and wall mounting kit give you the flexibility to use it in a multitude of scenarios. The DS52000 is backed for 2-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com Unmanaged 2.5G Switch, 5 Port Gigabit Switch, 2.5GBASE-T Unmanaged Ethernet Switch, Ethernet Splitter, Din Rail or Wall Mount, Multi-Gigabit, All-Metal, Auto-MDIX, 9K Jumbo - 2.5 Gb Network Switch - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Ports
5 x 10/100/1000/2.5G
Max Transfer Distance
100 m
Jumbo Frame Support
9KB
Flow control, auto-uplink (auto MDI/MDI-X), full duplex mode, QoS, fanless, EEE, security slot (Kensington security lock compatible)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az, IEEE 802.3bz
DC 12 V
14.5 cm x 12 cm x 3 cm
600 g
Enclosure Type
Desktop, wall-mountable
Subtype
Ports
100 m
Jumbo Frame Support
9KB
Status Indicators
Power, link/activity
5 x 2.5GBase-T RJ-45
Internal power supply
Power Provided
1 A
DC 12 V
Wall mounting kit
RoHS, WEEE, RCM
14.5 cm
12 cm
3 cm
600 g
Shipping Width
20.7 cm
Shipping Depth
14.4 cm
Shipping Height
3.8 cm
Shipping Weight
700 g
45 °C
10 - 90% RH
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Ports: 5
Managed: No
POE: No
