StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet
Quicklinx: 6B9YWS00 Mfr#: RKLCDBK
Product Type: Mounts
23 In Stock
£45.84 ex VAT
£55.00 inc VAT
Mount a 17-19 inch LCD panel into a standard 19 inch rack/cabinet. The RKLCDBK Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet lets you mount almost any retail LCD or Touch screen panel into a server/storage rack/cabinet. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
The LCD mounting bracket is made of solid cold pressed steel (SPCC), is designed to support 100mm and 75mm VESA mounted LCD panels, and meets ANSI/EIA RS-310-D standards rack mounting. A unique adjustable design enables an LCD panel to be mounted into the cabinet at various depths - allowing the rack/cabinet door to be closed.
The LCD mounting bracket also supports wall-mounted LCD installation, by inverting the adjustable bracket or by adding this bracket to a wall mount bracket or rack, such as the 6U (10 inch) Wallmount Bracket for 19" Rack Equipment (WALLMOUNT6) or 8U Open Frame Wall Mount Equipment Rack (RK812WALLO).
  • Sturdy construction
    The solid cold pressed steel material ensures that the mounting bracket is strong and reliable, providing a secure installation for your monitor.
  • Adjustable depth
    This feature allows for flexibility in mounting, accommodating different setups and ensuring the monitor is at the ideal distance for viewing.
  • Versatile VESA compatibility
    The bracket supports both 100 x 100 mm and 75 x 75 mm VESA mount interfaces, making it suitable for a variety of LCD displays.
StarTech.com 4U Universal VESA LCD Monitor Mounting Bracket for 19-inch Rack or Cabinet - TAA Compliant - Cold-Pressed Steel Bracket (RKLCDBK) mounting kit - for LCD display - black
Mounting kit
84.2 cm x 10.8 cm x 17.7 cm
Adjustable Depth
0-8.9 cm
1.7 kg
Recommended Use
LCD display
Recommended Display Size
19"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Material
Solid cold pressed steel
P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK25U, 4POSTRACK42, CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM62, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224, RK1233BKM, RK1236BKF, RK1833BKM, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK960CP
84.2 cm
10.8 cm
17.7 cm
Adjustable Depth
0-8.9 cm
1.7 kg
Material
AV Furniture
Mounting kit
Recommended Use
LCD display
19"
Adjustable depth
Limited warranty - lifetime
P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK960CP
6B9Y StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £68.51
6B9Y StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £45.84
6B9Y StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £79.46
6B9Y StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel In Stock £49.48
6B9Y StarTech.com 4U 19in Hinged Wall Mounting Bracket for Patch Panels In Stock £27.51
6B9Y StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £9.74
6B9Y StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £11.53
6B9Y StarTech.com 10-32 Server Rack Screws and Nuts - 50 Pack - Black - TAA Co In Stock £29.04
