This 6U (12in) high steel mounting bracket delivers a sturdy and dependable equipment storage option, allowing you to wallmount equipment for a more efficient and accessible operating environment. The mounting bracket features an all-steel design.
Durable construction
Made from high-quality steel, this bracket ensures long-lasting durability and strength to support network equipment. -
Space-saving design
Designed to be wall-mounted, it maximizes floor space and provides a tidy installation for easy access to cables and equipment. -
Standard rack compatibility
The 19-inch rack size is compliant with standards, allowing for a wide range of compatible equipment to be mounted.
- StarTech.com Wall Mount Patch Panel Bracket - 6U - 14in Deep (WALLMOUNT6) - cabinet - 6U
- Product Type
- Cabinet
- Placing / Mounting
- Wall mountable
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 6U
- Product Material
- Steel
- Product Type
- Cabinet
- Wall mountable
- Product Material
- Steel
- Rack Size
- 19"
- 6U
- Black
StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £35.78 |
StarTech.com 12U 19in Desktop Open Frame 2 Post Rack | In Stock | £40.61 |
StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £34.65 |
StarTech.com 3U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £39.01 |
StarTech.com 4U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £51.13 |
StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep | In Stock | £66.84 |
StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet | In Stock | £44.03 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £11.90 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £29.91 |
StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel | In Stock | £48.26 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £14.09 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £27.99 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £52.23 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £55.25 |
StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth | In Stock | £129.80 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £55.20 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £29.89 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £19.69 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £5.39 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £52.24 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £27.56 |
StarTech.com 50 Pkg M5 Mounting Screws | In Stock | £15.48 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £28.96 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £16.16 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £26.89 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £26.45 |
StarTech.com 12U WM Bracket for 12 INCH Equipment | In Stock | £119.16 |
StarTech.com 8U WM Bracket for 12in Equipment | In Stock | £101.09 |
StarTech.com 2-Post Desktop Rack - 8U | In Stock | £34.28 |
StarTech.com 18U Server Rack Enclosure | In Stock | £369.77 |
StarTech.com 6U Wall-Mount Rack Cabinet | In Stock | £148.99 |
StarTech.com 26U Server Rack Enclosure | In Stock | £470.78 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £174.53 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £193.99 |
StarTech.com 12U Server Rack Enclosure | In Stock | £330.35 |
StarTech.com 12U Server Rack Enclosure | In Stock | £276.36 |
StarTech.com 15U Server Rack Enclosure | In Stock | £313.10 |
StarTech.com 12U Server Rack Enclosure | In Stock | £375.79 |
StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs | In Stock | £26.53 |
StarTech.com 4U Wall Mount Rack, 13.78in Deep, 19 inch Wall Mount Network | In Stock | £44.88 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £16.78 |
