StarTech.com 18U Server Rack Enclosure
Quicklinx: CZD2WS00 Mfr#: RK1820WALHM
Depth (mm): 55cm
Width (mm): 60cm
Hurry, only 3 left in stock!
£369.77 ex VAT
£443.72 inc VAT
Use this wall-mount network cabinet to mount your server or networking equipment to the wall, with a hinged enclosure for easy access. This 18U server or network rack cabinet lets you mount your EIA-310 compliant equipment to the wall, in a secure enclosure that has a hinged rear door for easy access to your equipment. The enclosure features adjustable mounting depth from 2.4 to 20 in. to provide a robust storage solution for your rack-mount equipment.
To provide secure stability for your heaviest equipment, this rack offers 4-post mounting, supporting a higher weight capacity per U than 2-post racks and supporting a total load capacity of up to 200 lb. (90 kg).
Save valuable floor space by wall-mounting the enclosure. The wall-mounted design makes this enclosure the ideal solution for optimizing equipment storage in your classroom, retail store, server room or office. This rack also includes a 1U shelf that gives you a stable surface for placing equipment that's not rack-mountable or storing your tools.
The wall-mount network rack makes it easy to access your equipment and cabling, with a rear hinge that swings the enclosure away from the wall. By flipping the enclosure 180 degrees upon installation, you can reverse the direction of the hinge so that the enclosure can swing open from left or the right, depending on your preference.
The 18U network cabinet features a removable and reversible front door and removable side panels, each with quick-release mechanisms, so you can easily access your equipment. Plus, each door and panel on this rack features an independent lock, ensuring your equipment is secure.
For hassle-free cable management, the rack includes a 3 meter roll of hook-and-loop cable tie that makes it easy to keep your cables neat and tidy by binding them together or binding them to the rack. The self-gripping fabric can be cut to any size, enabling a wrap-around solution for the cables of any rack-mount equipment.
This server rack enclosure features heavy-duty steel construction, with lockable doors at all entrances. For hassle-free equipment installation, the mounting rails on the rack can be switched for use with square holes and cage nuts, or tapped rails.
To ensure your equipment is running at an optimal temperature, the server rack/cabinet promotes passive cooling. It features mesh doors and vented top and bottom panels for maximum airflow.
For simple and sturdy mounting, the rack's mounting holes are positioned 16 in. apart, so you can securely attach it to a wall using wall studs.
  • Premium Equipment Protection
    This wall mount equipment rack features premium-quality steel construction, with secure lockable front and back doors as well as lockable side panels. It features a grounding lug to prevent the build-up of static electricity which can result in electrostatic discharge (ESD), keeping your equipment protected from surges. This rack also offers dependable protection through both passive and active cooling. The mesh front doors and side panels along with the vents in the top offer passive cooling while the top offers placement support for 120mm fan mounts for an additional active cooling option.
  • Mount All Types of Equipment
    This 4-post server room cabinet has a weight capacity of up to 200 lbs. (90kg) and with a mounting depth from 2 to 16 inches, it can hold a variety of equipment. The mounting rails on the rack can be switched between both square cage nut hole or tapped 12-24 threaded hole styles. For non-mountable equipment, this rack also includes a 1U shelf. For hassle-free cable management, the rack includes a 3-meter roll of hook-and-loop cable tie that makes it easy to keep your cables neat and tidy by binding them together or binding them to the rack. The self-gripping fabric can be cut to any size, enabling a wrap-around solution for the cables of any rack-mount equipment.
  • Comprehensive Product Testing & Expert Technical Support
    StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to our customers. Our local StarTech.com Technical Advisors have broad product expertise and work directly with StarTech.com Engineers to provide support for our customers both pre and post-sales.
StarTech.com 18U 19" Wall Mount Network Cabinet, 16" Deep Hinged Locking IT Network Switch Depth Enclosure, Assembled Vented Computer Equipment Data Rack with Shelf & Flexible Side Panels - 18U Vented Cabinet (RK1820WALHM) - rack enclosure cabinet - 18U
Rack enclosure cabinet
Placing / Mounting
Wall mountable
Package Content
2 side panel keys, 2 door keys, 72 cage nuts, roll of hook-and-loop fastener, 72 screws (12-24)
Height (Rack Units)
18U
Product Material
Steel
60 cm x 55 cm x 90.4 cm
52 kg
Lockable front door, key lock, adjustable depth, hinged, mesh front door
5-year warranty
Placing / Mounting
Wall mountable
Product Material
Steel
Package Content
Height (Rack Units)
18U
60 cm
55 cm
90.4 cm
52 kg
Inner Dimensions
45 cm x 53 cm x 80 cm
Weight Limit
90 kg
Limited warranty: - 5 years
CZD2 StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £66.84
CZD2 StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £11.90
CZD2 StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.91
CZD2 StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.44
CZD2 StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.49
CZD2 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.71
CZD2 StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £52.23
CZD2 StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £55.25
CZD2 StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £31.67
CZD2 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
CZD2 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.23
CZD2 StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.45
CZD2 StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.24
CZD2 StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.00
CZD2 StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.41
CZD2 StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £22.90
CZD2 StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £55.20
CZD2 StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £29.89
CZD2 StarTech.com 100 Pkg M5 Cage Nuts In Stock £25.96
CZD2 StarTech.com 100 Pkg M5 Cage Nuts In Stock £30.61
CZD2 StarTech.com 50 Pkg M5 Cage Nuts In Stock £15.03
CZD2 StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £52.24
CZD2 StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £27.56
CZD2 StarTech.com 50 Pkg M5 Mounting Screws In Stock £15.48
CZD2 StarTech.com 100 Pkg M5 Mounting Screws In Stock £28.96
CZD2 StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.16
CZD2 StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.79
CZD2 StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.56
CZD2 StarTech.com 19in Cable Management Panel In Stock £23.35
CZD2 StarTech.com 26U Server Rack Enclosure In Stock £470.78
CZD2 StarTech.com 12U Server Rack Enclosure In Stock £330.35
CZD2 StarTech.com 12U Server Rack Enclosure In Stock £276.36
CZD2 StarTech.com 15U Server Rack Enclosure In Stock £313.10
CZD2 StarTech.com 12U Server Rack Enclosure In Stock £375.79
CZD2 StarTech.com M6 Mounting Screws 50Pack In Stock £16.79
CZD2 StarTech.com 42U Server Rack Cabinet In Stock £1,227.89
Depth (mm): 55cm
Width (mm): 60cm
