The Universal Laptop Lock is a versatile solution compatible with Noble Wedge ; K-Slot (T-Bar), or Nano, providing flexibility and convenience. With its on-the-fly lock tip change feature, you can quickly adapt the lock to different slot types. The cut-resistant steel security cable measures 6.5ft (2m) in length and 0.17in (4.4mm) thick, providing reach and durability. With the 3-in-1 Laptop Lock, protect your valuable devices wherever you go.
Combination Lock
The keyless cable lock allows you to set a personalized combination code, offering up to 10,000 combinations for increased security. The lock can withstand a pull force of 202 lb (91.6 kg) for K-slot, 164.4 lb (74.6 kg) for Nano, and 110.2 lb (50 kg) for Noble Wedge ; ensuring your computer or other devices remains safe from theft. Note: The pull force values mentioned may vary if the security slots do not comply with the design standards specified by their respective manufacturers. -
Widely Compatible
The versatile security lock is not limited to laptops or notebooks only. Use this lock to secure other devices such as docking stations, monitors, printers, SFF computers, projectors, oscilloscopes, or other office and lab equipment, expanding its utility. The lock is future-proof as it works with previous and newer computers from various brands, including HP, Dell, Microsoft, and more. Different thickness spacers are provided to ensure a better fit for your device. -
Full-Motion Lock Design
The diameter of the lock head is 0.4in (14mm) and features a ball joint design that allows for 360° rotation and 90° pivot of the lock head. This flexibility reduces coiling and minimizes strain on the notebook slot, enhancing durability and usability.
- StarTech.com Universal Laptop Lock 6.6ft (2m), Security Cable For Notebook Compatible With Noble Wedge/Nano/K-Slot; Keyless Combination Locking Cable - Anti-Theft Cut-Resistant Steel Cable (UNIVC4D-LAPTOP-LOCK) - security cable lock
- Product Type
- Security cable lock
- Black, silver
- Product Material
- Plastic, steel
- 3.2 cm 1.4 cm
- Length
- 2 m
- 2-year warranty
- Product Type
- Product Material
- Plastic, steel
- 3.2 cm
- 1.4 cm
- Length
- 2 m
- Shipping Dimensions (WxDxH) / Weight
- 15 cm x 18 cm x 2 cm / 144 g
- Black, silver
Security Cable Lock
- Intended For
- Notebook
- Lock Type
- T-Bar, nano, noble wedge
- Lock Method
- Key
- Limited warranty: - 2 years
StarTech.com Laptop Cable Lock Anchor - Computer Security Cable Anchor | In Stock | £10.22 |
StarTech.com Laptop Cable Lock Expansion Loop - 6" / 2.5 cm Branch Cable | In Stock | £6.34 |
StarTech.com Universal Laptop Lock, 3-in-1 | In Stock | £30.35 |
StarTech.com 25-Pack Universal Laptop Lock | In Stock | £507.39 |
StarTech.com 25-Pack Universal Laptop Lock | In Stock | £600.99 |
StarTech.com 25-Pack Universal Laptop Lock | In Stock | £627.35 |
StarTech.com 3-in-1 Universal Laptop Lock | In Stock | £27.51 |
StarTech.com Computer/Peripheral Lock Kit | In Stock | £32.44 |
StarTech.com Laptop Nano Cable Lock, 5ft | In Stock | £16.40 |
