StarTech.com Security Tether Cables - 5 Pack - Steel - Universal Cable
Quicklinx: FLXKWS00 Mfr#: CONNLOCKPK5
Device Type: Other
Type: Security
Device Screen Size: [N/A]
Colour: Silver
13 In Stock
£13.76 ex VAT
£16.51 inc VAT
Secure cables and adapters in boardrooms, workstations and other areas to help prevent against costly theft or accidental loss. These steel security tether cables provide a measure of physical security, by letting you attach your cables and adapters to each other.
The 5-pack of universal cable tethers give you an easy and cost-effective way to minimize the need to constantly replace cables in lobbies, public areas, work and meeting areas. They secure your cables and adapters, and also keep cables organized by making sure you always have the right adapter or cable in the right place.
The cable and adapter tethers are made of a durable steel cable with a PVC coating, providing an effective theft deterrent.
The flexible steel security cable is easy to wrap around your cables or adapters, and secure in place with the aluminum ferrules, using a standard crimping tool (not included). For versatile use, you can cut the 11.8" (300 mm) cable tethers to length, using wire cutters (not included). The steel tether does not restrict the space requirements or usage of the cable or adapter.
As an option, you can cover the aluminum ferrules with the black heat shrink tubing (included).
  • Robust material
    Constructed from steel, the security cable tethers offer a strong solution for securing adapters and dongles, minimizing the risk of theft or loss.
  • Practical accessories included
    The package contains 10 heat shrink tubings and 10 aluminum ferrules, providing components for effective and simple installation.
  • Environmentally compliant
    These tethers adhere to RoHS and REACH standards, ensuring that they are produced with materials that are safe for the environment.
StarTech.com 5-Pack Security Cable Tethers for Adapters & Dongles, Universal Cable Adapter Tether, Tether Cables, Adjustable Length Anti-Theft Cable Tether Lock Kit, Steel Cable Tether - Dongle Cable Tether (CONNLOCKPK5) - security cable
Security cable
Packaged Quantity
5 (specifications are for single item)
Package Content
10 heat shrink tubings, 10 x aluminium ferrules
Silver
Product Material
Steel
Length
30 cm
20 g
Packaged Quantity
Security cable
Product Material
Steel
Package Content
Length
30 cm
20 g
22 cm x 20 cm x 0.5 cm / 28.5 kg
Silver
RoHS, REACH
TAA Compliant
Limited warranty: - 2 years
FLXK StarTech.com Universal Laptop Lock, 3-in-1 In Stock £28.21
FLXK StarTech.com Universal Laptop Lock, 3-in-1 In Stock £30.84
FLXK StarTech.com 25-Pack Universal Laptop Lock In Stock £507.39
FLXK StarTech.com 25-Pack Universal Laptop Lock In Stock £600.99
FLXK StarTech.com 25-Pack Universal Laptop Lock In Stock £627.35
FLXK StarTech.com Tether Cables - 20 Pack - Steel In Stock £40.98
FLXK StarTech.com 3-in-1 Universal Laptop Lock In Stock £27.51
FLXK StarTech.com Computer/Peripheral Lock Kit In Stock £32.44
FLXK StarTech.com Peripheral Cable Anchor Lock In Stock £2.91
FLXK StarTech.com Universal Laptop Cable Lock In Stock £25.07
Device Type: Other
Type: Security
Colour: Silver
