StarTech.com Universal Dock USB-C & USB 3.0 100W PD
Quicklinx: F2JZWS00 Mfr#: DK30C2DPEPUE
Device Type: Macbook, Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black, Space grey
More than 50 In Stock
£142.64 ex VAT
£171.16 inc VAT
Transform your laptop into a dual-4K 60Hz workstation with this universal laptop docking station, for USB-C and USB 3.0 laptops. Connect to dual DisplayPort or HDMI monitors. Attach USB devices with four USB 3.0 ports. Plus, power your USB-C laptop with 100WPower Delivery.
The USB-C and USB 3.0 docking station provides IT professionals with a convenient one-dock solution for offices using different laptop brands and operating systems. The dock works with Dell, HP, Lenovo, MacBook and most other laptops.
The dual-4K docking station connects your laptop to Ultra HD DisplayPort or HDMI monitors: 2x 4K DisplayPort up to 4096 x 2160p @ 60Hz; 2x 4K HDMI up to 4096 x 2160p @ 60Hz; 1x 4K DP + 1x 4K HDMI display @ 60Hz.
Connect to a single 5K display using two DP ports.
Using a single cable, the dock powers and charges your laptop as you work with 100W PD for faster charging, using the 170W power adapter.
For fast setup right out of the box, the combo cable (USB-C with attached USB-A adapter) lets you connect any laptop. The dock has mounting holes for workstation mounting (bracket not included).
Connect your devices with four USB 3.0 ports: 1x USB-C and 3x USB-A. Fast-charge your USB-C or USB-A smartphone. The dock provides a GbE port (PXE Boot support) and 3.5 mm 4-position headset audio jack. It also includes a security lock slot (K-slot) to protect against theft.
  • The Uniquely Universal Host Cable
    The USB-C dock comes with a universal host cable that is designed with an attached USB-C to USB-A adapter to accommodate USB-A laptops. The cable also features an extended length of 1 meter (3.3 ft.) to support a wide variety of workstation setups. Replacement or extra cables can be purchased separately here.
  • 100W Power Delivery
    For high performance laptops that require more charging power, the dock powers and charges your laptop as you work with 100W PD for faster charging, using the 150W power adapter - all through a single cable.
  • Flexible Monitor Connections
    This is a dual 4K60Hz video docking station with support for both Ultra HD DisplayPort and/or HDMI monitors that lets you configure your video connections to best suit your needs. •Text | Dual 4K DisplayPort | Up to 4096 x 2160p @ 60Hz •Text | Dual 4K HDMI | Up to 4096 x 2160p @ 60Hz •Text | Single 4K DisplayPort + Single 4K HDMI | Up to 4096 x 2160p @ 60Hz •Text | Single 5K DisplayPort * | Up to 5120 × 2880 *Requires monitor support for 5K using two DP ports
  • Certified for Universal Compatibility & Reliability
    This docking station is fully certified to meet top industry standards for USB-IF (USB 3.1 Gen 1, USB Type-C and Power Delivery), VESA DisplayPort and DisplayLink (video connections) certification to guarantee the highest quality, reliability, and compatibility.
  • Easy and Convenient Setup
StarTech.com USB-C & USB-A Dock, Hybrid Universal Laptop Docking Station with 100W Power Delivery, Dual Monitor 4K 60Hz HDMI & DisplayPort, 4x USB 3.1 Gen 1 Hub, Gigabit Ethernet (GbE) - Hybrid USB Type-C Dock (DK30C2DPEPUE) - docking station - USB-C - 2 x HDMI, 2 x DP - 1GbE
Docking station
Docking Interface
USB-C
Video Interfaces
2 x HDMI, 2 x DP
22 cm x 8 cm x 3 cm
280 g
Black, space grey
United Kingdom, Europe
Gigabit Ethernet
Power adapter AC 120/230 V 170 Watt Power Provided
3-year warranty
Docking station
22 cm
8 cm
3 cm
280 g
Enclosure Colour
Black, space grey
Video
Max Resolution Details
4096 x 2160 - 60 Hz
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
1 x USB 3.1 Gen 1 with Power Delivery - 9 pin USB Type A , 2 x USB 3.1 Gen 1 with Power Delivery - 24 pin USB-C , 2 x display / video - 20 pin DisplayPort , 2 x display / video - 19 pin HDMI Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB 3.1 Gen 1 - 9 pin USB Type A , 1 x headphone/microphone combo jack - mini-phone 3.5 mm
1 x USB-C cable - external - 1 m
Security lock slot (cable lock sold separately), dual monitor support, Preboot Execution Environment (PXE) support, full duplex support, DisplayPort Alt Mode, 100W power delivery
Security Slot Type
Kensington security slot
FCC, RoHS, USB Battery Charging Specification Rev. 1.2, DisplayPort 1.2, UASP (USB Attached SCSI Protocol), USB Power Delivery 3.0
Power adapter
AC 120/230 V
Power Provided
170 Watt
Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 10.11, Apple macOS 10.12, Apple macOS 10.14, Apple macOS 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0, Ubuntu 18.04, Ubuntu 20.04, Google Chrome OS 55 or later
Limited warranty - 3 years
50 °C
F2JZ StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
F2JZ StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.22
F2JZ StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.58
F2JZ StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 In Stock £23.65
F2JZ StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £16.87
F2JZ StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.01
F2JZ StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.59
F2JZ StarTech.com Triple-Video Laptop Dock In Stock £92.02
F2JZ StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Pla In Stock £9.29
F2JZ StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £13.66
F2JZ StarTech.com USB-C USB-A Dock - Hybrid Triple Monitor Docking Station DP/HDMI 4K 60Hz 85W PD In Stock £173.49
F2JZ StarTech.com VESA Mounting Bracket In Stock £7.75
Device Type: Laptop
Colour: Black
Colour: Space grey
