StarTech.com 1m USB 3.1 USB-C to USB-A Cbl
Quicklinx: BFPDWS00 Mfr#: USB31AC1M
Length: 1m
Hurry, only 1 left in stock!
£9.82 ex VAT
£11.78 inc VAT
Express delivery Order within the next 3 hours for delivery on Monday
Connect your USB Type-C devices to your laptop or desktop computer. Need to connect your new USB Type-C device to a device with a traditional-style USB-A USB port? This 1m USB-C to USB-A cable is the perfect solution. It's also compatible with Thunderbolt 3 ports.
With a bandwidth of 10 Gbps, this USB 3.1 Gen 2 cable lets you sync your USB Type-C devices in no time at all.
Moving large files or transferring movies can be done in seconds - at twice the speed of USB 3.0 and 20x faster than USB 2.0 - all while charging your device with up to 3A, where supported.
You'll also be able to connect your USB 3.1 peripherals, such as hard drive enclosures and docks, to devices with a USB-A port. Now, you can spend less time transferring and backing up your data and more time focusing on your projects and presentations.
Connect your newer devices to older computers; USB 3.1 is backwards compatible with previous USB devices.
StarTech.com 3 ft 1m USB to USB C Cable - USB 3.1 10Gpbs - USB-IF Certified (USB31AC1M) - USB-C cable - 24 pin USB-C to USB Type A - 1 m
USB-C cable
Double shielded
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
9 pin USB Type A - male
USB 3.1
Works With Chromebook
P/N: 4SD4FCRU31C, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK31C3HDPD, DK31C3HDPDUE, DKM30CHDPD, DKM30CHDPDUE, HB30A4AIB, HB31C2A2CME, HB31C3A1CME, M2E1BMU31C, M2E1BRU31C, PEXUSB311AC3, PEXUSB312A1C1H, PEXUSB312A2C2V, PEXUSB312C3, PEXUSB314A2V2, SDOCK4U313
USB-C cable
Double shielded
Length
1 m
Connector
24 pin USB-C - male
USB 3.1, RoHS, USB-IF
P/N: 4SD4FCRU31C, BNDTBUSB3142, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK30CH2DPPD, DK30CH2DPPDU, DK31C3HDPD, DK31C3HDPDUE, DKM30CHDPD, DKM30CHDPDUE, DKT30CVAGPD, HB30A4AIB, HB30C3A1GE, HB30C3A1GEA, HB30C3AGEPD, HB30C4AIB, HB31C2A2CME, HB31C3A1CME, HBS304A24A, M2E1BMU31C, M2E1BRU31C, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311AC2, PEXUSB311AC3, PEXUSB311EI, PEXUSB312A1C1H, PEXUSB312A2, PEXUSB312A2C2V, PEXUSB312C2, PEXUSB312C3, PEXUSB312EIC, PEXUSB314A2V, PEXUSB314A2V2, S251BRU31C3, SDOCK4U313, TB33A1C
BFPD StarTech.com 1m USB 2.0 C to Micro-USB Cable In Stock £9.63
BFPD StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £10.55
BFPD StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £9.82
BFPD StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £11.37
BFPD StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.98
BFPD StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £9.21
BFPD StarTech.com 1m USB 2.0 USB-C to USB-B Cable In Stock £16.47
BFPD StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 In Stock £9.50
BFPD StarTech.com USB 3.0 USB-C to USB-A Adapter In Stock £8.21
BFPD StarTech.com USB-C to Micro-USB Adapter M/F In Stock £9.58
BFPD StarTech.com 6ft USB-C to A Cable - USB 2.0 In Stock £11.11
BFPD StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £17.80
BFPD StarTech.com 0.5m USB to USB-C Cable 10Gbps In Stock £9.03
Length: 1m
