Convert an SPDIF audio source signal to Digital Coax and Toslink either separately or simultaneously. The SPDIFCOAXTOS Two way Digital Coax to Toslink Audio Converter Repeater lets you extend and convert digital coax to Toslink audio, or Toslink to digital coax.
This small form-factor coax toslink converter is an easy to use solution allows you to select the input signal you want to convert or extend, and simultaneously outputs both digital coaxial and Toslink audio signals without downgrading the audio signal, and provides an output signal that matches the quality of input audio, supporting 2 to 5.1 channel audio.
- StarTech.com Two Way Digital Coax to Toslink Optical Audio Adapter Repeater - coaxial/optical digital audio converter
- Product Type
- Coaxial/optical digital audio converter
- White
- 1-year warranty
- Designed For
- P/N: SVA5M3NEUA
- Product Type
- White
- Connections
- Digital audio input (coaxial) - RCA , Digital audio input (optical) - TOS Link , Digital audio output (coaxial) - RCA , Digital audio output (optical) - TOS Link
- 1 year
- Designed For
- P/N: SVA5M3NEUA
StarTech.com SPDIF Digital Coaxial or Toslink Optical to Stereo RCA Audio Converter | In Stock | £32.94 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £12.01 |
