StarTech.com SPDIF Digital Coaxial or Toslink Optical to Stereo RCA Audio Converter
Quicklinx: 81TBWS00 Mfr#: SPDIF2AA
Type: Cable
Hurry, only 3 left in stock!
£32.14 ex VAT
£38.56 inc VAT
Convert a Digital Coax or Toslink Signal to Stereo RCA Audio. The SPDIF2AA Toslink/Optical SPDIF to RCA Audio Converter lets you convert a 2-channel Digital Coaxial or Toslink/Optical SPDIF input signal into an RCA analog stereo output.
Perfect for home and professional audio applications, this SPDIF to RCA audio converter saves the cost of upgrading equipment for compatible connections, and offers separate Digital Coax and Toslink inputs for dual-function conversion. The small form factor design makes it suitable for installation into virtually any location, regardless of space constraints, while still providing a lossless audio signal. Plus, the digital coaxial or Toslink to RCA converter supports plug-and-play installation, saving you time and hassle.
StarTech.com SPDIF Digital Coaxial or Toslink Optical to Stereo RCA Audio Converter - Digital Audio Adapter (SPDIF2AA) - coaxial/optical digital audio converter
Coaxial/optical digital audio converter
Product Material
Steel
4.2 cm 2.7 cm
Length
5.2 cm
78 g
P/N: FLATPNLCEIL, FLATPNLWALL, FPCEILPTBLP, FPCEILPTBSP, FPWARTB1M, FPWARTB2, FPWFXBAT, FPWTLTBAT, STNDMTV100, STNDMTV70, STNDMTVDUO, SVA5M3NEUA
Product Material
Steel
4.2 cm
2.7 cm
Length
5.2 cm
78 g
Digital audio input (coaxial) - RCA , Digital audio input (optical) - TOS Link , Audio line-out - RCA x 2
2 years
81TB StarTech.com 3 ft USB to Type M Barrel 5V DC Power Cable In Stock £5.05
81TB StarTech.com DC Power Adapter - 5V, 3A In Stock £11.96
Type: Cable
