This free-standing triple-monitor stand saves you valuable desk space, while creating a more comfortable and ergonomic workspace. Constructed of high grade steel, the sturdy monitor stand suspends monitors above your desk or other work surface.
Work with greater comfort and productivity
Clear up your desk surface while creating an ergonomic workspace. This computer monitor stand enhances your efficiency and productivity. It's ideal for offices, control rooms, banking, real estate and other real-time environments where multiple monitors are essential to productivity. Adjust your monitors to the ideal position with the articulating arms. Easily rotate up to 360°, tilt up to 30° up or down and swivel +30°/-30° to adjust your screen position. The structure allows smooth, effortless rotating and positioning for any direction, making it easy to reduce glare and find the ideal viewing angle. The micro-adjustment features enable level alignment. You can also adjust the height of your monitors along the vertical pole to reduce neck and eye strain. -
Rugged steel construction
With its heavy-duty steel construction and aluminum base, the triple-monitor stand holds your monitors securely and provides long-lasting performance. The surface finish helps to resist scratches. -
Easy installation
The monitor stand is designed for easy installation on your desk, table or other work surface. To help keep your work area free of clutter, the monitor stand also features cable clips that keep your cables neatly out of sight.
- StarTech.com Triple Monitor Stand for VESA Mount Monitors up to 27" - Steel (ARMBARTRIO2) stand - adjustable arm - for 3 monitors - black
- Product Type
- Stand (adjustable arm) - stand mountable
- Mounting Components
- End caps, pole, base plate, crossbar, washers, screws, collar, 2 monitor arms, VESA mount bracket, 2 thumbscrews
- 30 cm x 141.2 cm x 46.3 cm
- Rotation
- 360°
- Adjustments
- Height, pan, tilt
- 7 kg
- Recommended Use
- 3 monitors
- Recommended Display Size
- 13"-27"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 8 kg
- Material
- Plastic, aluminium, steel
- Black
- Package Content
- M4x12 screws, hex key (3mm), hex key (5mm), hex key (6mm), M5x12 screws, 2 x mounting-arm caps
- 5-year warranty
- Designed For
- P/N: DK30CH2DPPD, USB3DOCKH2DP
- 30 cm
- 141.2 cm
- 46.3 cm
- 7 kg
- Material
- Black
- Package Content
AV Furniture
- Stand
- Design
- Adjustable arm
- Recommended Use
- 3 monitors
- Placing / Mounting
- Stand mountable
- Cable Management
- Integrated cable management
- 13"-27"
- Rotation
- 360°
- Adjustments
- Height, pan, tilt
- Max Load Weight
- 8 kg
- Assembly Required
- Limited warranty - 5 years
- Designed For
StarTech.com Triple-Video Laptop Dock | In Stock | £89.78 |
StarTech.com Triple-Monitor Arm - Steel | In Stock | £143.14 |
StarTech.com Thin Client Mount - VESA | In Stock | £22.13 |
StarTech.com Under Desk Keyboard Tray | In Stock | £52.06 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £50.12 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £58.71 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £76.85 |
StarTech.com Triple Monitor Desk Mount | In Stock | £173.71 |
StarTech.com Triple Monitor Desk Mount | In Stock | £164.96 |
