Enhance your workspace with the StarTech.com Crossbar Triple Monitor Desk Mount, designed for flexibility and efficiency. This mounting kit supports three LCD displays ranging from 17" to 27", allowing for a seamless multitasking experience. With features like 360° rotation, swivel, and tilt adjustments, it offers the perfect viewing angles to suit your needs. The built-in cable management system ensures your workspace remains tidy, while the construction of aluminum, plastic, and steel ensures stability and durability. Easy to install, it comes with all necessary tools and screws, making it a great addition to any professional setting.
Versatile adjustments
With capabilities for extension, pivot, rotation up to 360°, swivel from -10° to 10°, and tilt from -15° to 5°, this triple monitor desk mount offers flexibility to find the perfect viewing angles for productivity and comfort. -
Robust build quality
Crafted from a combination of aluminum, plastic, and steel, the Crossbar Triple Monitor Desk Mount is designed for durability and stability, securely supporting three LCD displays ranging from 17" to 27". -
Efficient cable management
Featuring a built-in cable management channel, this mounting kit ensures that your workspace remains tidy and organized, free from the clutter of cables. -
Easy installation
The package includes all necessary assembly tools and a comprehensive selection of screws, making the setup process straightforward and hassle-free for a seamless integration into your workspace.
- StarTech.com Crossbar Triple Monitor Desk Mount, VESA 75x75/100x100 mounting kit - adjustable arm - for 3 LCD displays - triple monitor mount - black
- Product Type
- Mounting kit (adjustable arm) - desk-mountable
- 63 cm x 140 cm
- Adjustable Height
- 26.5-59.5 cm
- Tilt
- -15° to 5°
- Rotation
- 360°
- Swivel
- -10° to 10°
- Adjustments
- Pivot, extension
- 8.4 kg
- Recommended Use
- 3 LCD displays
- Recommended Display Size
- 17"-27"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 6 kg
- Material
- Plastic, aluminium, steel
- Black
- Package Content
- Hex key (4mm), hex key (3mm), 12 x M4x12 screws, 2 x M5x8 screws, hex key (6mm), swivel arm, mounting base, 6 x cable management clip, 2 hand knobs, 3 x VESA monitor mounts, 12 x M5x12 screws, tool holder, spring arm, base pad, 3 x crossbars, grab handle, 2 x desk clamp discs, 2 x desk clamps, 10 x counter-sink screws, 4 x button head screws, 2 x M4x10 screws, 12 x washers, 2 x washers (small), 8 x hook and loop straps
- 5-year warranty
- 63 cm
- 140 cm
- Adjustable Height
- 26.5-59.5 cm
- 8.4 kg
- Material
- Black
- Package Content
AV Furniture
- Mounting kit
- Design
- Adjustable arm
- Recommended Use
- 3 LCD displays
- Placing / Mounting
- Desk-mountable
- Cable Management
- Cable management channel
- 17"-27"
- Tilt
- -15° to 5°
- Rotation
- 360°
- Swivel
- -10° to 10°
- Adjustments
- Pivot, extension
- Max Load Weight
- 6 kg
- Assembly Required
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 33 cm x 61 cm x 15 cm / 10 kg
- Limited warranty - 5 years
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £77.54 |
StarTech.com 24" Monitor Privacy Screen | In Stock | £79.81 |
StarTech.com 27" Monitor Privacy Screen | In Stock | £103.98 |
StarTech.com 25" Monitor Privacy Screen | In Stock | £73.04 |
