StarTech.com Triple Monitor Stand - Steel
Quicklinx: D69MWS00 Mfr#: ARMBARTRIO2
Accessory Type: Stand
Hurry, only 3 left in stock!
£169.33 ex VAT
£203.19 inc VAT
This free-standing triple-monitor stand saves you valuable desk space, while creating a more comfortable and ergonomic workspace. Constructed of high grade steel, the sturdy monitor stand suspends monitors above your desk or other work surface.
  • Work with greater comfort and productivity
    Clear up your desk surface while creating an ergonomic workspace. This computer monitor stand enhances your efficiency and productivity. It's ideal for offices, control rooms, banking, real estate and other real-time environments where multiple monitors are essential to productivity. Adjust your monitors to the ideal position with the articulating arms. Easily rotate up to 360°, tilt up to 30° up or down and swivel +30°/-30° to adjust your screen position. The structure allows smooth, effortless rotating and positioning for any direction, making it easy to reduce glare and find the ideal viewing angle. The micro-adjustment features enable level alignment. You can also adjust the height of your monitors along the vertical pole to reduce neck and eye strain.
  • Rugged steel construction
    With its heavy-duty steel construction and aluminum base, the triple-monitor stand holds your monitors securely and provides long-lasting performance. The surface finish helps to resist scratches.
  • Easy installation
    The monitor stand is designed for easy installation on your desk, table or other work surface. To help keep your work area free of clutter, the monitor stand also features cable clips that keep your cables neatly out of sight.
StarTech.com Triple Monitor Stand for VESA Mount Monitors up to 27" - Steel (ARMBARTRIO2) stand - adjustable arm - for 3 monitors - black
Stand (adjustable arm) - stand mountable
Mounting Components
End caps, pole, base plate, crossbar, washers, screws, collar, 2 monitor arms, VESA mount bracket, 2 thumbscrews
30 cm x 141.2 cm x 46.3 cm
Rotation
360°
Adjustments
Height, pan, tilt
7 kg
Recommended Use
3 monitors
Recommended Display Size
13"-27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Plastic, aluminium, steel
Package Content
M4x12 screws, hex key (3mm), hex key (5mm), hex key (6mm), M5x12 screws, 2 x mounting-arm caps
5-year warranty
P/N: DK30CH2DPPD, USB3DOCKH2DP
30 cm
141.2 cm
46.3 cm
7 kg
Material
Package Content
AV Furniture
Stand
Mounting Components
Design
Adjustable arm
Recommended Use
3 monitors
Placing / Mounting
Stand mountable
Cable Management
Integrated cable management
13"-27"
Rotation
360°
Adjustments
Height, pan, tilt
Max Load Weight
8 kg
Assembly Required
Limited warranty - 5 years
D69M StarTech.com Triple-Video Laptop Dock In Stock £95.44
D69M StarTech.com Triple-Monitor Arm - Steel In Stock £144.45
D69M StarTech.com Thin Client Mount - VESA In Stock £22.53
D69M StarTech.com Under Desk Keyboard Tray In Stock £55.81
D69M StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £53.32
D69M StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £59.75
D69M StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £77.01
D69M StarTech.com Triple Monitor Desk Mount In Stock £178.05
D69M StarTech.com Triple Monitor Desk Mount In Stock £167.93
