StarTech.com Thunderbolt 3 Dual - 4K Dock
Quicklinx: CC39WS00 Mfr#: TB3DK2DPWUE
With a single cable, connect your Windows laptop to dual-4K monitors (60Hz) and multiple peripherals at the unrivaled speed of 40Gbps. This Thunderbolt 3 dock is the first docking station to use revolutionary Thunderbolt 3 technology. Plus, it's the first dock available that supports two 4K Ultra HD 60Hz displays.
The high-quality dock merges performance with simplicity, to create a single-cable solution that caters to creative professionals such as video producers, graphic and web designers, engineers, architects, and many more.
You can quickly integrate the dock into your workspace and boost your productivity. With up to 40Gbps of throughput, you can add extra displays to your laptop, access files faster, and reduce waiting, so you can accomplish more in the same amount of time.
It's the fastest connection available, and it supports multiple video channels, data, and power, without impacting system performance. It's easy to access and edit large uncompressed files such as videos and images on the fly, making it ideal for dynamic on-site production.
If you need a larger, higher-resolution viewing area, this dock can help. It's one of the first docking stations to support two 4K Ultra HD displays, so it's perfect for anyone working with high-bandwidth or graphics-intensive multimedia. And, unlike most traditional docking stations, the Thunderbolt 3 dock supports 4K (3840 x 2160p) resolutions at 60Hz. With a faster 60Hz refresh rate, your 4K content is delivered in stunning detail and with less lag that 30Hz alternatives, even when you're running resource-demanding applications.
You can extend your desktop onto two 4K monitors and stream independent content to each display. This makes it easier to multitask when you're working with high-definition video, CAD drawings, medical imagery, or other complex work. Creative professionals can be more productive with the freedom to edit 4K video on one display, with a full-size video preview on the second 4K display.
Plus, for advanced 5K resolution requirements, this dock supports a single 5K display when you connect your monitor to one of the Thunderbolt 3 ports, delivering 5120 x 2880p resolutions at 60Hz.
Using a single cable and a single port on your laptop, you can transform your Windows laptop into a full-size workstation with access to new and legacy technologies through a number of different port types. The dock is ideal for virtually all Windows based Thunderbolt 3 equipped laptops such as the Dell Precision, and Dell XPS.
The dock features two Thunderbolt 3 USB-C ports for connecting to Thunderbolt devices and other peripherals that use the USB-C connector, as well as DisplayPort video output. For dual 4K video capability, you can use a 4K 60Hz capable video adapter to connect a second 4K 60Hz display to one of the dock's Thunderbolt 3 USB-C peripheral ports.
You can keep your mobile device charged and ready to go using the dock's convenient, always-on USB fast-charge and sync port (compliant with USB Battery Charging Specification 1.2). Plus, it offers a variety of other connections that are often missing from port-limited laptops, such as an extra USB-C port (5Gbps - data only), and a Gigabit Ethernet port.
With three total USB 3.0 ports, you have plenty of ports to connect modern and legacy devices. (USB 3.0 is also known as USB 3.1 Gen 1). Now, you can rest assured knowing you're ready for the current and next generation of universal connectivity.
The rear-panel DP and USB-C port can be used with dual monitors that support lower resolutions, such as 4K 30Hz or 1080p. Now you can connect dual monitors using new and legacy displays. StarTech.com offers a variety of USB-C video adapters, such as CDP2HD HDMI and CDP2VGA VGA.
StarTech.com Thunderbolt 3 Dual 4K Docking Station for Laptops Windows Only - docking station - Thunderbolt - DP - GigE
Docking station
Docking Interface
Thunderbolt
Video Interfaces
DP
22 cm x 8 cm x 2.6 cm
500 g
Gigabit Ethernet
Power adapter AC 120/230 V
3-year warranty
Docking station
22 cm
8 cm
2.6 cm
500 g
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, USB 3.1
2 x Thunderbolt 3 - 24 pin USB-C , 1 x display / video - DisplayPort output - 20 pin DisplayPort , 1 x USB 3.1 - 24 pin USB-C , 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x audio - line-in/microphone - mini-phone stereo 3.5 mm , 1 x audio - line-out/headphones , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x Thunderbolt cable - external - 50 cm
Wake on LAN, LED indicator, UASP transfer protocol, 1 USB 3.0 fast charging port, full duplex support
FCC, RoHS, USB Battery Charging Specification Rev. 1.2
Power adapter
AC 120/230 V
Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
Limited warranty - 3 years
5 °C
CC39 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £12.84
CC39 StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.86
CC39 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £15.98
CC39 StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £15.80
CC39 StarTech.com DisplayPort to DVI Active Adapter In Stock £22.91
CC39 StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £21.79
CC39 StarTech.com 6 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £23.85
CC39 StarTech.com 3ft DP to HDMI cable - 4K In Stock £14.50
CC39 StarTech.com DP to VGA Adapter with Audio In Stock £23.64
CC39 StarTech.com USB-C to VGA Adapter In Stock £23.98
CC39 StarTech.com USB-C to VGA Adapter - White In Stock £21.61
CC39 StarTech.com 4 Port USB 3.0 Hub - USB-C Hub In Stock £34.22
CC39 StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.98
CC39 StarTech.com USB-C to HDMI Adapter In Stock £22.02
CC39 StarTech.com USB-C to HDMI Adapter In Stock £22.69
CC39 StarTech.com Thunderbolt 3 to Thunderbolt In Stock £106.46
CC39 StarTech.com 0.5m Thunderbolt 3 Cable In Stock £19.39
CC39 StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £32.27
CC39 StarTech.com 6ft USB-C to DisplayPort Cable In Stock £28.80
CC39 StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.26
