StarTech.com Thin Client Mount - VESA
Quicklinx: D8W4WS00 Mfr#: ACCSMNT
Accessory Type: Mount
£22.48 ex VAT
£26.97 inc VAT
Save space and neatly mount your docking station, thin client or USB hub to a VESA mount, behind your monitor, or under your desk. This thin-client mounting bracket provides an excellent space-saving solution, by letting you mount your thin-client PC or docking station to create a clutter-free workspace.
The versatile double-sided VESA mount offers several installation options, enabling you to mount your thin-client PC or dock to the back of your monitor or under your desktop, or clamp it to a monitor-mount pole. The mount supports 75x75, and 100x100 VESA mount compatibility, making it suitable for most monitors and monitor mounts.
This adjustable mount is ideal for holding an Intel NUC, Mac Mini, most small CPUs, thin clients, docking stations, or USB hubs that fit within the width adjustability of the mount (.7" to 2.8" / 17 mm to 70 mm). The mount can support up to 11 lb. (5 kg). It also features an adjustable strap to help keep your devices secure, and rubber pads to secure products with non-parallel surfaces.
The open-frame design of the mount allows unrestricted access to your computer.
  • Versatile mounting options
    This product allows for flexible placement, enabling users to mount it under the desk or on a pole, providing multiple installation choices based on individual needs.
  • Durable construction
    Crafted from a combination of plastic and steel, this mount ensures long-lasting use and stability for your devices.
  • Adjustable width
    The adjustable feature allows compatibility with various thin client devices, ensuring a snug fit for different applications.
  • Heavy-duty support
    With a maximum load capacity of 5 kg, this mount can securely hold devices while maintaining a clean and organized workspace.
  • Complete mounting kit included
    This product comes with all necessary hardware, including screws and washers, to facilitate a seamless installation process.
StarTech.com Thin Client Mount - Mini PC VESA Mount - Adjustable .7 to 2.8" - Under Desk Computer Mount - Mac Mini Monitor Mount (ACCSMNT) mounting component - for thin client - black
Mounting component - under-the-desk, pole mount, monitor
Mounting Components
Pole mount, strap, VESA mount bracket
7 cm x 11.8 cm x 12.9 cm
Adjustments
666 g
Recommended Use
Thin client
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
5 kg
Material
Plastic, steel
Package Content
8 x M4x12 screws, 4 x washers, 4 x screws, 6 x pads, 2 x M5x25 screws, 4 x M4 nuts
5-year warranty
P/N: ARMBARDUO, ARMBARDUOV, ARMBARTRIO2, ARMCBCL, ARMDUAL, ARMDUAL30, ARMDUALSS, ARMDUALV, ARMPIVOT, ARMPIVOTB, ARMPIVOTE, ARMPIVOTE2, ARMPIVOTHD, ARMPIVOTV2, ARMPIVSTND, ARMSLIM, ARMSLIMDUO, ARMTRIO, ARMUNONB, ARMUNONB1, DK30A2DH, DK30C2DAGPD, DK30C2HAGPD, FPPNEUSTND, TB3DK2DPM2, TB3DK2DPPD
7 cm
11.8 cm
12.9 cm
666 g
Material
Plastic, steel
Package Content
AV Furniture
Mounting component
Mounting Components
Recommended Use
Thin client
Placing / Mounting
Under-the-desk, pole mount, monitor
Adjustments
Max Load Weight
5 kg
Limited warranty - 5 years
P/N: ARMBARDUO, ARMBARDUOV, ARMBARTRIO2, ARMCBCL, ARMDUAL, ARMDUAL30, ARMDUALSS, ARMDUALV, ARMPIVOT, ARMPIVOTB, ARMPIVOTE, ARMPIVOTE2, ARMPIVOTHD, ARMPIVOTV2, ARMPIVSTND, ARMSLIM, ARMSLIMDUO, ARMTRIO, ARMUNONB, ARMUNONB1, DK30A2DH, DK30C2DAGPD, DK30C2HAGPD, FPPNEUSTND, TB3DK2DPM2, TB3DK2DPPD, USB3SDOCKDD
D8W4 StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £135.75
D8W4 StarTech.com Height Adjustable Monitor Arm - Grommet / Desk Mount with Cable Hook In Stock £63.34
D8W4 StarTech.com Monitor Mount - USB Passthrough In Stock £157.69
D8W4 StarTech.com Dual Monitor Mount - Stackable In Stock £212.26
D8W4 StarTech.com Dual Monitor Stand In Stock £80.12
D8W4 StarTech.com TV/Monitor Arm - Wallmount In Stock £82.22
D8W4 StarTech.com Quad Monitor Stand - Steel In Stock £188.41
D8W4 StarTech.com Vertical Dual Monitor Stand In Stock £78.44
D8W4 StarTech.com Monitor Arm - Heavy Duty In Stock £93.15
D8W4 StarTech.com Adjustable CPU Wall Mount In Stock £32.51
D8W4 StarTech.com TV Accessory Mount - Universal - Media Player/Apple TV In Stock £26.75
D8W4 StarTech.com PC Wall Mount Bracket/Holder In Stock £57.85
D8W4 StarTech.com Computer Tower Cart, Rolling In Stock £31.35
D8W4 StarTech.com VESA Mounting Bracket In Stock £7.61
