Robust construction
Crafted from steel, this computer tower cart offers a sturdy foundation for your personal computer, ensuring it remains secure whether in motion or stationary. -
Versatile mobility
Equipped with four wheels, this rolling CPU caddy provides effortless mobility, allowing you to easily move your computer to the desired location without the need for heavy lifting. -
Adjustable design
The adjustable frame accommodates various computer tower sizes, ensuring a snug fit for enhanced stability. This flexibility makes it an ideal choice for a wide range of personal computers. -
Enhanced stability
Included anti-slip pads for both the side walls and base prevent movement and slipping, ensuring your computer stays securely in place even on smooth surfaces.
- StarTech.com Computer Tower Cart Rolling CPU Caddy w/ Wheels, Adjustable cart - for personal computer - black
- Product Type
- Cart
- 25.7 cm x 27 cm
- Adjustable Width
- 13.2-22 cm
- 3.4 kg
- Recommended Use
- Personal computer
- Max Load Weight
- 21 kg
- Material
- Steel
- Black
- Wheels Qty
- 4
- Package Content
- 4 x washers, wrench, base, 4 x casters, 2 x side walls, 2 x side walls anti-slip pads, base anti-slip pad, 4 x assembly screws, 4 x wing nuts
- 5-year warranty
- 25.7 cm
- 27 cm
- Adjustable Width
- 13.2-22 cm
- 3.4 kg
- Material
- Steel
- Black
- Package Content
AV Furniture
- Cart
- Recommended Use
- Personal computer
- Max Load Weight
- 21 kg
- Wheels Qty
- 4
- Limited warranty - 5 years
StarTech.com Rolling TV Cart/Portable Mount | In Stock | £432.67 |
