Save space and neatly mount your docking station, thin client or USB hub to a VESA mount, behind your monitor, or under your desk. This thin-client mounting bracket provides an excellent space-saving solution, by letting you mount your thin-client PC or docking station to create a clutter-free workspace.
The versatile double-sided VESA mount offers several installation options, enabling you to mount your thin-client PC or dock to the back of your monitor or under your desktop, or clamp it to a monitor-mount pole. The mount supports 75x75, and 100x100 VESA mount compatibility, making it suitable for most monitors and monitor mounts.
This adjustable mount is ideal for holding an Intel NUC, Mac Mini, most small CPUs, thin clients, docking stations, or USB hubs that fit within the width adjustability of the mount (.7" to 2.8" / 17 mm to 70 mm). The mount can support up to 11 lb. (5 kg). It also features an adjustable strap to help keep your devices secure, and rubber pads to secure products with non-parallel surfaces.
The open-frame design of the mount allows unrestricted access to your computer.
Versatile mounting options
This product allows for flexible placement, enabling users to mount it under the desk or on a pole, providing multiple installation choices based on individual needs. -
Durable construction
Crafted from a combination of plastic and steel, this mount ensures long-lasting use and stability for your devices. -
Adjustable width
The adjustable feature allows compatibility with various thin client devices, ensuring a snug fit for different applications. -
Heavy-duty support
With a maximum load capacity of 5 kg, this mount can securely hold devices while maintaining a clean and organized workspace. -
Complete mounting kit included
This product comes with all necessary hardware, including screws and washers, to facilitate a seamless installation process.
- StarTech.com Thin Client Mount - Mini PC VESA Mount - Adjustable .7 to 2.8" - Under Desk Computer Mount - Mac Mini Monitor Mount (ACCSMNT) mounting component - for thin client - black
- Product Type
- Mounting component - under-the-desk, pole mount, monitor
- Mounting Components
- Pole mount, strap, VESA mount bracket
- 7 cm x 11.8 cm x 12.9 cm
- Adjustments
- 666 g
- Recommended Use
- Thin client
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 5 kg
- Material
- Plastic, steel
- Black
- Package Content
- 8 x M4x12 screws, 4 x washers, 4 x screws, 6 x pads, 2 x M5x25 screws, 4 x M4 nuts
- 5-year warranty
- Designed For
- P/N: ARMBARDUO, ARMBARDUOV, ARMBARTRIO2, ARMCBCL, ARMDUAL, ARMDUAL30, ARMDUALSS, ARMDUALV, ARMPIVOT, ARMPIVOTB, ARMPIVOTE, ARMPIVOTE2, ARMPIVOTHD, ARMPIVOTV2, ARMPIVSTND, ARMSLIM, ARMSLIMDUO, ARMTRIO, ARMUNONB, ARMUNONB1, DK30A2DH, DK30C2DAGPD, DK30C2HAGPD, FPPNEUSTND, TB3DK2DPM2, TB3DK2DPPD
- 7 cm
- 11.8 cm
- 12.9 cm
- 666 g
- Material
- Plastic, steel
- Black
- Package Content
AV Furniture
- Recommended Use
- Thin client
- Placing / Mounting
- Under-the-desk, pole mount, monitor
- Adjustments
- Max Load Weight
- 5 kg
- Limited warranty - 5 years
- Designed For
- P/N: ARMBARDUO, ARMBARDUOV, ARMBARTRIO2, ARMCBCL, ARMDUAL, ARMDUAL30, ARMDUALSS, ARMDUALV, ARMPIVOT, ARMPIVOTB, ARMPIVOTE, ARMPIVOTE2, ARMPIVOTHD, ARMPIVOTV2, ARMPIVSTND, ARMSLIM, ARMSLIMDUO, ARMTRIO, ARMUNONB, ARMUNONB1, DK30A2DH, DK30C2DAGPD, DK30C2HAGPD, FPPNEUSTND, TB3DK2DPM2, TB3DK2DPPD, USB3SDOCKDD
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £139.14 |
StarTech.com Height Adjustable Monitor Arm - Grommet / Desk Mount with Cable Hook | In Stock | £64.93 |
StarTech.com Monitor Mount - USB Passthrough | In Stock | £161.64 |
StarTech.com Dual Monitor Mount - Stackable | In Stock | £217.58 |
StarTech.com Dual Monitor Stand | In Stock | £82.12 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £84.28 |
StarTech.com Quad Monitor Stand - Steel | In Stock | £193.12 |
StarTech.com Vertical Dual Monitor Stand | In Stock | £80.40 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £95.48 |
StarTech.com Adjustable CPU Wall Mount | In Stock | £33.33 |
StarTech.com PC Wall Mount Bracket/Holder | In Stock | £60.24 |
StarTech.com Computer Tower Cart, Rolling | In Stock | £31.64 |
StarTech.com VESA Mounting Bracket | In Stock | £7.61 |
