StarTech.com Tablet Stand - Desk/Wall Mount
Quicklinx: CWBXWS00 Mfr#: ARMTBLTDT
Device Type: Phone, Tablet, iPad
Type: Tablet Stand
Device Screen Size: 4.7 - 12.9
Colour: Black
£27.69 ex VAT
£33.22 inc VAT
Increase productivity by mounting your tablet on your desk, to a wall, or under a cabinet. Integrate your iPad or other tablet seamlessly into your workspace, with this universal tablet stand. Move the tablet arm up or down, and rotate the tablet to adjust your viewing position instantly. The tablet stand rests securely on your desk, or you can mount it to a wall, or on the underneath surface of a cabinet or cupboard.
With this highly adjustable tablet stand, you can maximize use of your tablet without having to hold it in your hand or place it down on your desk.
Simply move the tablet arm up or down, with its two movable joints, to position your tablet at the perfect height. The tablet arm pivots 0° / +170° at the base and -40° / +180° at the elbow, to allow easy adjustment of the tablet positioning. Switch easily from portrait to landscape position, with 360° rotation.
The clamp spreads apart easily to hold a tablet or phone from 4.7" to 12.9" in size, and up to 1 kg (2.2 lb.) in weight. With its large base, the tablet stand rests securely on your desk, counter or other flat surface. A smaller base is also included, which lets you mount the tablet stand to a wall, or on the bottom surface of a work cabinet or kitchen cupboard, for a wide range of applications.
  • Versatile design
    The stand accommodates a wide range of tablet sizes, enhancing its usability in different environments.
  • Stable support
    With robust materials and stable mounting components, this stand ensures that tablets are securely held in place, preventing unwanted movement during use.
  • Space-saving solution
    By enabling wall mounting, the tablet stand efficiently saves valuable desk space while providing optimal placement for effective viewing.
StarTech.com Universal Tablet Stand - Portable Tablet Stand w/ Optional Wallmount Base - Adjustable Pivoting Tablet Stand (ARMTBLTDT) mounting kit - adjustable arm - for tablet
Mounting kit (adjustable arm) - wall-mountable
Mounting Components
Wall plate, stand base, knob, base cover
16 cm x 16 cm x 35 cm
Rotation
360°
Adjustments
Height, lift
1.4 kg
Recommended Use
Tablet
Recommended Display Size
4.7"-12.9"
Max Load Weight
1 kg
Material
Plastic, aluminium
Package Content
Hex key (4mm), hex key (3mm), hex key (2.5mm), 2 x screws, 2 x concrete anchors
5-year warranty
P/N: DK30CHPH, STSCART
16 cm
16 cm
35 cm
1.4 kg
Material
Plastic, aluminium
Package Content
AV Furniture
Mounting kit
Mounting Components
Design
Adjustable arm
Recommended Use
Tablet
Placing / Mounting
Wall-mountable
4.7"-12.9"
Rotation
360°
Adjustments
Height, lift
Max Load Weight
1 kg
Limited warranty - 5 years
CWBX StarTech.com 11 Piece PC Computer Tool Kit with Carrying Case In Stock £16.42
CWBX StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.01
CWBX StarTech.com Tripod Floor Stand for Tablets In Stock £53.00
CWBX StarTech.com Mobile Sit Stand Workstation In Stock £244.57
CWBX StarTech.com 1 m / 3.3 ft USB 2.0 to USB C Cable – Black In Stock £8.64
CWBX StarTech.com 2 m / 6.6 ft USB 2.0 to USB C Cable – Black In Stock £10.10
CWBX StarTech.com 1 m / 3.3 ft USB C Cable – Black In Stock £8.89
Device Type: Phone
Device Type: Tablet
Device Type: iPad
Type: Tablet Stand
Colour: Black
