Securely mount your 9.7" iPad to create a sleek POS system or interactive marketing kiosk. Now you can safely secure your tablet in a locked enclosure and mount it on a table, desk or wall. This secured tablet holder for iPad is the perfect way to utilize your tablet as an interactive marketing kiosk, educational tool, product display or a multitude of other applications.
Imagine all the ways you could use a self-standing tablet in your organization. Greet clients with helpful information. Connect customers to your own app to enhance the user experience. Or, use a tablet as a sleek point-of-sale (POS) system.
The attractive metal enclosure provides an impressive display unit to showcase your own apps or new products and services. The home button is covered, allowing you to direct users to specific information or apps, while preventing them from navigating the tablet at their leisure.
On a wall or desk surface, the secure enclosure lets you create an interactive user experience while protecting your tablet. Simply slide your iPad into the steel enclosure to help protect it from loss or damage. The holder supports Apple iPad and iPad Air, with 9.7" screen size. The lock guards against theft, with a secure locking mechanism. While your tablet is in use, you can be sure it's held safely and securely in place in the enclosure.
The tablet holder's robust, solid-steel construction provides maximum durability, protection, and stability. It's easy to mount to your desk, table or wall, to provide security and a comfortable viewing position, and the lockable enclosure can be mounted directly to a VESA compatible monitor mount for easy adjustability.
Secure Design
The lockable feature of the Secure Tablet Enclosure Stand protects the device against theft in high-traffic areas, making it suitable for public displays where security is a concern. -
Versatile Mounting Options
The stand can be mounted on a wall or placed on a desktop, providing flexibility in how and where it is used, ideal for adapting to various environments. -
360° Rotation Functionality
The ability to rotate the tablet 360° allows users to switch between portrait and landscape orientations easily, beneficial for presentations or different applications. -
Robust Steel Construction
Constructed from steel, this stand offers stability and robustness, ensuring long-term use without compromising integrity. -
Complete Mounting Kit Included
The package comes with all necessary components, including a mount bracket, pads, and keys for a straightforward setup.
- StarTech.com Secure Tablet Enclosure Stand- Lockable Anti Theft Steel Desk or Wall Mount for 9.7" iPad / Tablet - VESA Compatible (SECTBLTPOS) stand - for tablet - black
- Product Type
- Stand - wall-mountable, desktop - lockable
- Mounting Components
- Mount bracket, pads, front plate, rear plate
- 31.2 cm 20.05 cm
- Rotation
- 360°
- Recommended Use
- Tablet
- Recommended Display Size
- 9.7"
- VESA Mounting Interface
- 100 x 100 mm
- Max Mounting Pattern Size
- 100 x 100 mm
- Material
- Steel
- Black
- Package Content
- 2 keys, 2.5mm allen key, 4 x 2.5mm hex screws
- 5-year warranty
- Designed For
- P/N: DK30CHPH
- 31.2 cm
- 20.05 cm
- Material
- Steel
- Black
- Package Content
AV Furniture
- Stand
- Recommended Use
- Tablet
- Placing / Mounting
- Wall-mountable, desktop
- 100 x 100 mm
- 100 x 100 mm
- Lockable
- 9.7"
- Rotation
- 360°
- Limited warranty - 5 years
- Designed For
- P/N: DK30CHPH
StarTech.com 11 Piece PC Computer Tool Kit with Carrying Case | In Stock | £14.09 |
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £9.01 |
StarTech.com Lockable Floor Stand for iPad | In Stock | £137.81 |
StarTech.com Tablet Stand - Desk/Wall Mount | In Stock | £27.26 |
StarTech.com 1 m / 3.3 ft USB 2.0 to USB C Cable – Black | In Stock | £8.64 |
StarTech.com 2 m / 6.6 ft USB 2.0 to USB C Cable – Black | In Stock | £10.10 |
StarTech.com 1 m / 3.3 ft USB C Cable – Black | In Stock | £8.89 |
StarTech.com Secure tablet stand, Desk/wall | In Stock | £31.80 |
StarTech.com VESA Mount Adapter for Tablets | In Stock | £22.48 |
StarTech.com Adjustable Tablet Stand | In Stock | £28.89 |
