Clone or erase 2.5in/3.5in SATA hard drives, without a host computer connection. The SATDUP11 standalone hard drive duplicator eraser enables you to copy 1-to-1 hard drive without a host computer.
Featuring three modes of standalone drive duplication including Data Only, All Partitions, and Sector by Sector, the HDD copier offers high performance duplication, and has been tested for speeds up to 14GB per minute.
Complete with integrated LCD display, and support for 2.5" and 3.5" SATA I/II/III hard drives (HDD) and Solid State Drives (SSD), the SATDUP11 is a user-friendly all-in-one solution for any application requiring hard drive duplication or erasing.
The SATDUP11 features high quality aluminum construction.
- StarTech.com 1:1 Hard Drive Duplicator and Eraser for 2.5" & 3.5" SATA HDD SSD - LCD & RS-232 - 14GBpm Duplication Speed - Cloner & Wiper (SATDUP11) - hard drive duplicator
- Hard drive duplicator
- Black
- Installed Devices / Modules Qty
- 0 (installed) / 2 (max)
- Supported Drives
- SATA-600
- Localisation
- North America, United Kingdom, Europe
- Built-in Devices
- Status LCD
- Storage Controller
- SATA (SATA 6Gb/s)
- Power
- AC 120/230 V - 50/60 Hz
- 7.7 cm x 11.5 cm x 2.5 cm
- 500 g
- 2-year warranty
- Designed For
- P/N: SVA12M5NA
- Enclosure Colour
- Black
- Localisation
Chassis
- Built-in Devices
- Status LCD
- 0
- Supported Devices / Modules Qty
- 2
- Supported Drives
- SATA-600
Storage Controller
- SATA
- Interface Type
- SATA 6Gb/s
- Max Storage Devices Qty
- 2
- Expansion Bays
- 2 (total) / 2 (free) x external - 2.5" / 3.5" shared
- 2 x SATA 6Gb/s - 22 pin Serial ATA
- Cables Included
- 2 x Serial ATA cable
- FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- 7.7 cm
- 11.5 cm
- 2.5 cm
- 500 g
- Limited warranty - 2 years
- 5 °C
- 45 °C
- 20 - 80%
- Designed For
- P/N: SVA12M5NA
StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap | In Stock | £3.36 |
StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks | In Stock | £20.67 |
StarTech.com 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock | In Stock | £411.23 |
StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) | In Stock | £12.60 |
StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter | In Stock | £14.59 |
StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure | In Stock | £37.78 |
StarTech.com 1:2 Standalone USB 2.0 Flash Drive Duplicator and Eraser | In Stock | £116.33 |
StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator and Eraser w/ High Duplication Speed | In Stock | £305.50 |
StarTech.com Standalone 1:5 USB Flash Drive Duplicator and Eraser | In Stock | £482.76 |
StarTech.com SATA/SAS Duplicator & Eraser | In Stock | £1,128.94 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.16 |
StarTech.com USB Duplicator and Eraser 1:15 | In Stock | £1,147.98 |
StarTech.com USB Duplicator and Eraser 1:7 | In Stock | £663.80 |
StarTech.com M.2 SATA & M.2 NVMe Duplicator | In Stock | £681.14 |
