The SAT2MSAT25 2.5in SATA to Mini SATA SSD Adapter Enclosure turns an mSATA (Mini SATA) mini-SSD into a standard 2.5in SATA SSD for use anywhere a 2.5in SATA drive can be used. Featuring all of the standard mounting points that a normal 2.5in hard drive uses, the converter can be installed into External Hard Drive Enclosures, Hard Drive Docking Stations or into desktop or laptop computers. The enclosure also features a unique design that enables seamless data pass-through with no conversion bottlenecks, enabling the mSATA drive to work as fast as it's allowed by the host system/interface.
- StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure - Mini PCIe ssd Adapter - SATA to mSATA - Mini PCIe SATA (SAT2MSAT25) - storage enclosure - SATA
- Storage enclosure - external
- Bus Type
- SATA
- Silver
- Hard Drive Form Factor Compatibility
- 2.5"
- Supported Devices
- Hard drive
- Channel Qty
- 1
- Product Material
- Plastic, aluminium
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista
- 6.8 cm x 9.8 cm x 1 cm
- 50 g
- 2-year warranty
- Designed For
- P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, SATDUP11, SATDUP11IMG, SATERASER4, SATSASDUPE11, SU2DUPERA11
- 2.5"
- Host Bus
- SATA
- Product Material
- Silver
Storage Controller
- Supported Devices
- Hard drive
- Channel Qty
- 1
- Processor
- No CPU
- 1 x SATA 3Gb/s - SATA
- Connections
- 1 storage - Serial ATA-300 - 52 pin mini-SATA
- RoHS
- OS Required
- Limited warranty - 2 years
- 6.8 cm
- 9.8 cm
- 1 cm
- 50 g
- 0 °C
- 50 °C
- 50 - 95%
- Designed For
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.58 |
StarTech.com 36in SATA Serial ATA Cable | In Stock | £5.68 |
StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable | In Stock | £5.36 |
StarTech.com 12in Latching SATA Cable | In Stock | £5.48 |
StarTech.com 12in SATA Serial ATA Cable | In Stock | £4.44 |
StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F | In Stock | £6.14 |
StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure | In Stock | £30.84 |
StarTech.com mSATA to SATA HDD / SSD Adapter – Mini SATA to SATA Converter Card | In Stock | £13.12 |
StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm | In Stock | £19.99 |
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £16.17 |
StarTech.com mSATA SSD to 2.5in SATA Adapter Converter | In Stock | £18.80 |
StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter | In Stock | £35.55 |
StarTech.com M.2 NGFF to SATA Adapter | In Stock | £21.11 |
StarTech.com Dual M.2 NGFF SATA Adapter w/ RAID - 2x M.2 SSDs to 2.5in SATA | In Stock | £31.73 |
StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter | In Stock | £19.59 |
StarTech.com M.2 to U.2 Adapter | In Stock | £24.14 |
StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe | In Stock | £135.99 |
