StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator and Eraser w/ High Duplication Speed
Quicklinx: 92PYWS00 Mfr#: SATDUP11
Hurry, only 3 left in stock!
£305.50 ex VAT
£366.60 inc VAT
Clone or erase 2.5in/3.5in SATA hard drives, without a host computer connection. The SATDUP11 standalone hard drive duplicator eraser enables you to copy 1-to-1 hard drive without a host computer.
Featuring three modes of standalone drive duplication including Data Only, All Partitions, and Sector by Sector, the HDD copier offers high performance duplication, and has been tested for speeds up to 14GB per minute.
Complete with integrated LCD display, and support for 2.5" and 3.5" SATA I/II/III hard drives (HDD) and Solid State Drives (SSD), the SATDUP11 is a user-friendly all-in-one solution for any application requiring hard drive duplication or erasing.
The SATDUP11 features high quality aluminum construction.
StarTech.com 1:1 Hard Drive Duplicator and Eraser for 2.5" & 3.5" SATA HDD SSD - LCD & RS-232  - 14GBpm Duplication Speed - Cloner & Wiper (SATDUP11) - hard drive duplicator
Hard drive duplicator
0 (installed) / 2 (max)
Supported Drives
SATA-600
North America, United Kingdom, Europe
Built-in Devices
Status LCD
Storage Controller
SATA (SATA 6Gb/s)
AC 120/230 V - 50/60 Hz
7.7 cm x 11.5 cm x 2.5 cm
500 g
P/N: SVA12M5NA
Enclosure Colour
Chassis
Built-in Devices
Status LCD
0
Supported Devices / Modules Qty
2
Supported Drives
SATA-600
Storage Controller
SATA
Interface Type
SATA 6Gb/s
Max Storage Devices Qty
2
Expansion Bays
2 (total) / 2 (free) x external - 2.5" / 3.5" shared
2 x SATA 6Gb/s - 22 pin Serial ATA
2 x Serial ATA cable
FCC, RoHS
External power adapter
7.7 cm
11.5 cm
2.5 cm
500 g
5 °C
45 °C
20 - 80%
P/N: SVA12M5NA
92PY StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.36
92PY StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £20.67
92PY StarTech.com 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock In Stock £411.23
92PY StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.60
92PY StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter In Stock £14.59
92PY StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure In Stock £37.78
92PY StarTech.com 1:2 Standalone USB 2.0 Flash Drive Duplicator and Eraser In Stock £125.59
92PY StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator and Eraser w/ High Duplication Speed In Stock £305.50
92PY StarTech.com Standalone 1:5 USB Flash Drive Duplicator and Eraser In Stock £482.91
92PY StarTech.com SATA/SAS Duplicator & Eraser In Stock £1,128.94
92PY StarTech.com DC Power Adapter - 12V, 5A In Stock £41.16
92PY StarTech.com USB Duplicator and Eraser 1:15 In Stock £1,147.98
92PY StarTech.com USB Duplicator and Eraser 1:7 In Stock £663.80
92PY StarTech.com M.2 SATA & M.2 NVMe Duplicator In Stock £681.14
Type: Hard drive Duplicator
HD Size: 2.5 / 3.5 shared
Power Supply: Power adapter
