StarTech.com Slimline DB9 Serial Gender Changer - F/F
Quicklinx: 7GS7WS00 Mfr#: GC9SF
£4.74 ex VAT
£5.68 inc VAT
This Slimline DB9 Gender Changer features two slimline DB9F connectors, offering a reliable, cost-saving way to convert a 9 pin male port to a 9 pin female port. The Slimline DB9 Gender Changer guarantees long-lasting performance.
  • Seamless connectivity
    The Slimline DB9 Serial Gender Changer by StarTech.com offers a straightforward solution for connecting two male serial devices. This gender changer ensures a reliable connection between PC peripherals, enhancing your setup's efficiency.
  • Durable design
    Crafted for longevity, this serial gender changer features a robust construction that can withstand the rigors of daily use. Its compact size makes it an unobtrusive addition to any workstation.
  • Lifetime warranty
    StarTech.com stands behind their product with a lifetime limited warranty, providing peace of mind and assurance of quality.
StarTech.com Slimline DB9 Serial Gender Changer - F/F - Serial gender changer - DB-9 (F) to DB-9 (F) - GC9SF - serial gender converter - DB-9 to DB-9
Serial gender converter
Connector
9 pin D-Sub (DB-9) - female
Connector (Second End)
P/N: ICUSB2324852, ICUSB422, ICUSB422IS, NETRS232, NETRS2321P, NETRS2321POE, NETRS2322P, NETRS232485W
Connector
7GS7 StarTech.com 4P Serial to Ethernet Adapter In Stock £305.29
