This monitor desk mount supports up to six 32-inch displays, creating an ergonomic multi-monitor setup that is ideal for data aggregation and monitoring applications. The dual-column design, sturdy aluminum construction, and enhanced c-clamp base ensure long-lasting stability, preventing tilting and evenly distributing weight across the desk. The monitor mounts are VESA 75x75/100/100 compatible, and feature individual micro-height adjustment for precise alignment of each monitor. The ergonomic VESA mounts support +/-17° swivel, +/-34° tilt, and 360° screen rotation, with each display mount supporting up to 17.6lb (8kg). Monitors can be positioned along the 71.1-inch (1.8m) wide crossbars, with outer monitors angled (+/-16°) toward the user. The mount offers dual mounting options: robust C-clamps for desks from 0.4 to 2.9in (1 to 7.5cm) thick or grommet hole mounts for desks from 0.4 to 1.7in (1 to 4.5cm) thick. Each crossbar can be positioned along the two 33.5-inch (85.3cm) columns, providing flexible height options. All VESA plates are removable for easy installation or removal of the monitors. Cable clips for the crossbars and columns keep cables neatly tucked away, and accessories like cable ties and hooks (parts HKLP25GN and CBMZT8B) help maintain an organized workspace.
Dual-Column Stability
The dual-column design, sturdy aluminum construction, and enhanced c-clamp base ensure long-lasting stability. This design prevents tilting over time and evenly distributes weight across the desk for reliable support. -
Perfect 3x2 Setup
This monitor setup is ideal for data aggregation and monitoring applications such as financial analysis, security monitoring, control rooms, and other activities that require an extensive viewing area. Individual micro-height adjustment enables precise alignment of each monitor. -
Display Adjustment
The ergonomic VESA plate support +/-17° swivel, +/-34° tilt, and 360° screen rotation for portrait or landscape orientation, and 75x75/100 patterns. Each display mount can support up to 17.6lb (8kg). Every monitor can be positioned along the 71.1-inch (1.8m) wide crossbars. The outer monitors can be angled (+/-16°) toward the user. -
Convenient Installation
The mount offers dual mounting options: robust C-clamps for desks from 0.4 to 2.9in (1 to 7.5cm) thick or grommet hole mounts for desks from 0.4 to 1.7in (1 to 4.5cm) thick. Each crossbar can be positioned along the two 33.5-inch (85.3cm) columns, providing flexible height options. All VESA plates are removable for easy installation or removal of the monitors. -
Organized Workspace
To maintain an organized workspace, the mount includes cable clips for the crossbars and columns to keep cables neatly tucked away and out of sight. Combine accessories such as cable ties and hooks (parts HKLP25GN and CBMZT8B) for a tidier setup.
- StarTech.com Six-Monitor Desk Mount w/ Crossbar, Up To 32" Screens/17.6lb mounting kit - for 6 LCD displays - column, dual - white
- Product Type
- Mounting kit - desk-mountable
- 180 cm x 11.8 cm
- Adjustable Height
- 20.2-52.9 cm
- Tilt
- -15° to 65°
- Rotation
- 360°
- Swivel
- -15° to 15°
- Adjustments
- Height, pivot, rotation, swivel, tilt
- 14 kg
- Recommended Use
- 6 LCD displays
- Recommended Display Size
- 17"-32"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Material
- Steel, plastic
- White
- Package Content
- 2 x desk clamps, 2 x grommet base plate, 2 x grommet clamp plate, 2 x columns, 6 x crossbars, 4 x crossbar munting brackets, 6 x VESA bracket, 6 x VESA bracket screws, 8 x cable-management clips (crossbar), 4 x cable management clips, 2 x endcaps, 2 x base caps, 10 x clamp pads, 8 x base screws, 16 x crossbar screws, 8 x button head screws, 4 x socket head screws, level, 24 x M4x12 screw, hex key (4mm), hex key (5mm), hex key (6mm), 24 x M4x16 screws, 24 x M5x12 screws, 24 x M5x16 screws, 24 x spacers, 24 x washers
- 5-year warranty
- 180 cm
- 11.8 cm
- Adjustable Height
- 20.2-52.9 cm
- 14 kg
- Material
- Steel, plastic
- White
- Package Content
AV Furniture
- Mounting kit
- Recommended Use
- 6 LCD displays
- Placing / Mounting
- Desk-mountable
- Cable Management
- Cable management clips
- 17"-32"
- Tilt
- -15° to 65°
- Rotation
- 360°
- Swivel
- -15° to 15°
- Adjustments
- Assembly Required
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 100 cm x 40.5 cm x 12 cm
- Limited warranty - 5 years
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £75.65 |
StarTech.com 32in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £113.52 |
StarTech.com 24" Monitor Privacy Screen | In Stock | £76.22 |
StarTech.com 25" Monitor Privacy Screen | In Stock | £63.96 |
