StarTech.com 24" Monitor Privacy Screen
Quicklinx: HQ2SWS00 Mfr#: 2461A-PRIVACY-SCREEN
Accessory Type: Privacy Screen
15 In Stock
£83.61 ex VAT
£100.33 inc VAT
Hang this universal 24" 16:10 aspect ratio Monitor Privacy Screen on the top edge of a 24" monitor to obscure the view of sensitive on-screen information. Silicone bumpers ensure a secure and damage-free application.
  • Enhanced privacy
    Equipped with microlouver privacy technology, this 24-inch 16:10 Monitor Privacy Screen from StarTech.com ensures your data remains confidential by limiting the viewing angle to +/- 30°. Ideal for high-traffic areas or those who frequently work with sensitive information.
  • Versatile installation
    Featuring a plug-in design with hanging hooks, this privacy screen offers a straightforward setup, making it easy to attach or remove as needed. Its compatibility with 24" wide displays ensures a perfect fit for your monitor.
  • Durable and clean
    Crafted from acrylic, this display privacy filter is not only scratch-resistant but also boasts a fingerprint-resistant coating, ensuring your screen stays clear and readable, while the glossy surface finish enhances screen clarity.
StarTech.com 24-inch 16:10 Monitor Privacy Screen, Hanging Filter/Shield - display privacy filter - 24" wide
Display privacy filter - 2-way
Installation Type
Removable - plug-in
Package Content
Wiping cloth, 6 silicone bumpers
Display Screen Size Compatibility
24" wide
Product Material
Acrylic
34 cm x 54 cm x 2.3 cm
600 g
Package Content
24" wide
Product Material
Acrylic
34 cm - 54 cm - 2.3 cm
600 g
38.9 cm x 60.2 cm x 4 cm / 1.1 kg
Display Filter
Privacy Protection
2-way
Installation Type
Removable - plug-in
Aspect Ratio
16:10
Surface Finish
Glossy
Scratch Resistant
+/- 30° visible angle, horizontal orientation, hanging hook, microlouver privacy technology, fingerprint-resistant coating, 65% light transmittance
