StarTech.com Six-Monitor Desk Mount/Max 32"
Quicklinx: J4KWWS00 Mfr#: 6-MONITOR-ARM-A
13 In Stock
£277.24 ex VAT
£332.68 inc VAT
This monitor desk mount supports up to six 32-inch displays, creating an ergonomic multi-monitor setup that is ideal for data aggregation and monitoring applications. The dual-column design, sturdy aluminum construction, and enhanced c-clamp base ensure long-lasting stability, preventing tilting and evenly distributing weight across the desk. The monitor mounts are VESA 75x75/100/100 compatible, and feature individual micro-height adjustment for precise alignment of each monitor. The ergonomic VESA mounts support +/-17° swivel, +/-34° tilt, and 360° screen rotation, with each display mount supporting up to 17.6lb (8kg). Monitors can be positioned along the 71.1-inch (1.8m) wide crossbars, with outer monitors angled (+/-16°) toward the user. The mount offers dual mounting options: robust C-clamps for desks from 0.4 to 2.9in (1 to 7.5cm) thick or grommet hole mounts for desks from 0.4 to 1.7in (1 to 4.5cm) thick. Each crossbar can be positioned along the two 33.5-inch (85.3cm) columns, providing flexible height options. All VESA plates are removable for easy installation or removal of the monitors. Cable clips for the crossbars and columns keep cables neatly tucked away, and accessories like cable ties and hooks (parts HKLP25GN and CBMZT8B) help maintain an organized workspace.
  • Dual-Column Stability
    The dual-column design, sturdy aluminum construction, and enhanced c-clamp base ensure long-lasting stability. This design prevents tilting over time and evenly distributes weight across the desk for reliable support.
  • Perfect 3x2 Setup
    This monitor setup is ideal for data aggregation and monitoring applications such as financial analysis, security monitoring, control rooms, and other activities that require an extensive viewing area. Individual micro-height adjustment enables precise alignment of each monitor.
  • Display Adjustment
    The ergonomic VESA plate support +/-17° swivel, +/-34° tilt, and 360° screen rotation for portrait or landscape orientation, and 75x75/100 patterns. Each display mount can support up to 17.6lb (8kg). Every monitor can be positioned along the 71.1-inch (1.8m) wide crossbars. The outer monitors can be angled (+/-16°) toward the user.
  • Convenient Installation
  • Organized Workspace
    To maintain an organized workspace, the mount includes cable clips for the crossbars and columns to keep cables neatly tucked away and out of sight. Combine accessories such as cable ties and hooks (parts HKLP25GN and CBMZT8B) for a tidier setup.
StarTech.com Six-Monitor Desk Mount w/ Crossbar, Up To 32" Screens/17.6lb mounting kit - for 6 LCD displays - column, dual - white
Mounting kit - desk-mountable
180 cm x 11.8 cm
Adjustable Height
20.2-52.9 cm
Tilt
-15° to 65°
Rotation
360°
Swivel
-15° to 15°
Adjustments
Height, pivot, rotation, swivel, tilt
14 kg
Recommended Use
6 LCD displays
Recommended Display Size
17"-32"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Material
Steel, plastic
White
Package Content
2 x desk clamps, 2 x grommet base plate, 2 x grommet clamp plate, 2 x columns, 6 x crossbars, 4 x crossbar munting brackets, 6 x VESA bracket, 6 x VESA bracket screws, 8 x cable-management clips (crossbar), 4 x cable management clips, 2 x endcaps, 2 x base caps, 10 x clamp pads, 8 x base screws, 16 x crossbar screws, 8 x button head screws, 4 x socket head screws, level, 24 x M4x12 screw, hex key (4mm), hex key (5mm), hex key (6mm), 24 x M4x16 screws, 24 x M5x12 screws, 24 x M5x16 screws, 24 x spacers, 24 x washers
5-year warranty
180 cm
11.8 cm
Adjustable Height
20.2-52.9 cm
14 kg
Material
Steel, plastic
White
Package Content
AV Furniture
Mounting kit
Recommended Use
6 LCD displays
Placing / Mounting
Desk-mountable
Cable Management
Cable management clips
17"-32"
Tilt
-15° to 65°
Rotation
360°
Swivel
-15° to 15°
Adjustments
Assembly Required
Dimensions & Weight Details
100 cm x 40.5 cm x 12 cm
Limited warranty - 5 years
J4KW StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £77.54
J4KW StarTech.com 32in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £116.35
J4KW StarTech.com 24" Monitor Privacy Screen In Stock £79.81
J4KW StarTech.com 27" Monitor Privacy Screen In Stock £103.98
J4KW StarTech.com 25" Monitor Privacy Screen In Stock £73.04
