Add an AC outlet and two USB charge ports in your boardroom, classroom or huddle space with this meeting room power center.
Conveniently Power and Charge Devices
Modern office environments need to support technology more than ever, to keep laptops, phones and tablets connected with this desktop power outlet with USB. During meetings, lectures and conferences, you may need access to power when your battery is running low or a meeting is running long. Providing a conference table power outlet, this conference table charging station makes it easy to power laptops using the AC power outlets, and charge phones and tablets using the 2.4 amp USB ports. -
Easy, Stylish and Clean Installation
Design a practical and stylish solution that impresses your visitors and facilitates their needs. The recessed power strip socket is easy to install in a conference room table, desk or lectern, and features a black aluminum finish that complements your table and your peripherals. -
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. KITBZPOWUK is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com Conference Table Power Center with 1x CE Certified BS1363 AC Outlet & 2x USB BC 1.2, Recessed In-Table/Desk Power Strip/Charging Station for Meeting Room/Boardroom/Lab Bench - Charging Station Hub (KITBZPOWUK) - power strip
- Power strip - external
- Localisation
- United Kingdom
- Output Voltage
- AC 100-240 V
- Output connectors
- 1 x power BS 1363 , 2 x 4 pin USB Type A 2.4 A
- Black
- 14.5 cm x 10 cm x 11.5 cm
- 2-year warranty
- Black
- Localisation
- United Kingdom
- Frequency Provided
- 50/60 Hz
- Power Output Connectors Details
- Output Voltage
- AC 100-240 V 50/60 Hz
- Max Electric Current
- 9.5 A
- Cables Included
- Power cable - external
- Recessed mount, cable management
- Battery Charging 1.2, EMC 2014/30/EU, LVD 2014/35/EU
- Limited warranty - 2 years
- 14.5 cm
- 10 cm
- 11.5 cm
StarTech.com 0.5m Micro USB Cable A to Micro B | In Stock | £2.42 |
StarTech.com 3m Micro USB Cable M/M - USB A to Micro B | In Stock | £6.22 |
StarTech.com 3m UK Computer Power Cord - 3 Pin Mains Lead - C13 to BS-1363 | In Stock | £6.10 |
StarTech.com 2m BS-1363 to C13 Y-Cable | In Stock | £8.42 |
