StarTech.com 3m Micro USB Cable M/M - USB A to Micro B
Quicklinx: 87PHWS00 Mfr#: UUSBHAUB3M
Length: 3m
15 In Stock
£6.32 ex VAT
£7.58 inc VAT
Charge or sync Micro USB mobile devices from a standard USB port on your desktop or mobile computer.
The UUSBHAUB3M USB-A to Micro-B Cable (3m) provides a high quality connection between Micro USB-equipped USB 2.0 mobile devices (such as BlackBerry or Android-based smart phones, digital cameras, PDAs, Tablet PC devices and GPS systems) and a USB-capable computer, for everyday tasks such as data synchronization and file transfers.
  • Durable construction
    The cable features a braided design that provides enhanced durability, allowing it to withstand regular use without fraying or breaking.
  • Reliable data transfer
    This USB cable supports USB 2.0 standards, ensuring stable and efficient data transfer for compatible devices.
  • Flexible connectivity
    Equipped with a 4-pin USB Type-A connector and a 5-pin Micro-USB Type-B connector, this cable offers versatile compatibility with multiple devices.
StarTech.com 3m Micro USB Cable M/M USB A to Micro B - USB cable - USB to Micro-USB Type B - 3 m
USB cable
Shielded
Braided
Length
3 m
Connector
4 pin USB Type A - male
Connector (Second End)
5 pin Micro-USB Type B - male
USB / USB 2.0
P/N: KITBXAVHDPEU, KITBXAVHDPUK
USB cable
Shielded
American Wire Gauge (AWG)
28
Braided
Length
3 m
Connector
USB / USB 2.0, RoHS
87PH StarTech.com 1m Micro USB Cable - A to Micro B In Stock £5.38
87PH StarTech.com 2m Micro USB Cable - A to Micro B In Stock £6.09
87PH StarTech.com 0.5m Micro USB Cable A to Micro B In Stock £2.42
87PH StarTech.com 3m Micro USB Cable M/M - USB A to Micro B In Stock £6.32
Length: 3m
