StarTech.com Single Port Server KVM console with KVM Switch
Quicklinx: F07KWS00 Mfr#: RKCONS1701
£639.58 ex VAT
£767.49 inc VAT
Providing centralized control of your PC, server, or KVM switch, this single-port rackmount KVM console gives you easy access to your connected system. With a minimal footprint, it mounts in a server rack or cabinet using only 1U of rack space.
The 1U rackmount console features a built-in keyboard, a touchpad for intuitive control, and a 17-inch LCD display that supports resolutions up to 1280x1024.
This single-port KVM console includes everything you need to set up right out of the box: 1 VGA KVM Cable; Mounting Rails; M5 Cage Nuts and Screws.
The rack console features a single-port KVM module, which can be connected directly to a server or PC, or to a KVM switch for access to multiple systems. The KVM module offers the flexibility you need for easily integrating the console into your existing server infrastructure.
Rack consoles provide convenient, rack-mounted control options for single servers or entire server rooms. KVM consoles include LCD display, keyboard, and trackpad, all sliding into 1U of rack space.
  • Efficient design
    The Rackmount KVM Console features a fully featured universal 1U LCD KVM drawer design, making it an efficient space-saving solution for managing servers.
  • High-quality display
    Equipped with a 17-inch TFT active matrix display that supports 16.7 million colors, the console offers a native resolution of 1280 x 1024. Its raised bezel type and 5:4 image aspect ratio ensure clear and vibrant visuals from any viewing angle.
  • Durable and reliable
    Designed for longevity in demanding environments, the console boasts a mean time between failures (MTBF) of 50,000 hours, ensuring reliability and performance.
  • Versatile connectivity
    This KVM console supports a VGA interface and USB for keyboard and mouse connections, accommodating a wide range of hardware configurations.
  • Easy installation
    With a rack mounting kit included and a height of only 1 rack unit (1U), the console is easy to install, making it an ideal choice for any server room or data center.
StarTech.com Rackmount KVM Console, Single Port VGA KVM with 17" LCD Monitor for Server Rack, Fully Featured Universal 1U LCD KVM Drawer with Cables & Hardware, USB Support, 50,000 MTBF - LCD KVM Concole Drawer (RKCONS1701) - KVM console - 17"
KVM console - 17"
KVM Switch
USB - 1 ports
Keyboard, touchpad
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
16.7 million colours
Input Connectors
VGA
Voltage
AC 120/230 V
44.8 cm x 47.1 cm x 4.25 cm
Height (Rack Units)
1U
11.7 kg
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
Display Type
KVM console / TFT active matrix
Diagonal Size
17"
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Height (Rack Units)
1U
11.7 kg
Input
Keyboard, touchpad
KVM
KVM switch - 1 ports
Keyboard / Mouse Interface
USB
Max Resolution
1280 x 1024 @ 60 Hz
VGA
8 x M5 cage nuts, 8 x M5 screws, 2 x mounting rails
1 x keyboard / mouse / video cable - 1.83 m
Rack Mounting Kit
Included
MTBF
50,000 hour(s)
Input Voltage
AC 120/230 V
Power Consumption (Typical)
13 Watt
Shipping Weight
17.1 kg
10 - 80% (non-condensing)
F07K StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £452.75
F07K StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £514.22
F07K StarTech.com 4 Port 1U Rackmount USB KVM Switch with OSD In Stock £142.79
F07K StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £273.74
F07K StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £309.46
F07K StarTech.com 17" Dual Rail Rackmount KVM Console with 1080p In Stock £904.75
F07K StarTech.com Rackmount KVM Console - 8 Ports with 17" LCD Monitor In Stock £974.99
F07K StarTech.com Rackmount KVM Console - 16 Ports with 17" LCD Monitor In Stock £1,083.73
F07K StarTech.com 10 ft. (3 m) USB KVM Cable for Rackmount Consoles In Stock £29.38
F07K StarTech.com 15 ft. (4.6 m) USB KVM Cable for Rackmount Consoles In Stock £39.35
F07K StarTech.com 6 ft. (1.8 m) USB KVM Cable for Rackmount Consoles In Stock £17.16
