StarTech.com Shielded Cat 6a Keystone Jack - RJ45 Ethernet Cat6a Wall Jack White - 110 Type
Quicklinx: 92P8WS00 Mfr#: C6AKEY110WH
Terminate your shielded Cat6a cables at standard wall plates. The C6AKEY110WH Cat 6a Keystone Jack is designed to snap into wall plates, patch panels, and surface connection boxes for quick, seamless deployment.
Meeting and exceeding the international standard ISO / IEC 11801 and the ANSI/TIA-568-C.2 requirements, this RJ45 keystone jack provides the perfect solution for your Ethernet networks.
StarTech.com Shielded Cat 6a Keystone Jack - RJ45 Ethernet Cat6a Wall Jack White - 110 Type - RJ45 (F) to 110 Punch Down Shielded (C6AKEY110WH) - modular insert
Modular insert - CAT 6a
2.1 cm x 3.81 cm x 1.6 cm
15.5 g
White
Port Qty
1 port
2.1 cm
3.81 cm
1.6 cm
15.5 g
Enclosure Colour
White
Cabling & Wiring
Port Qty
1 port
Termination Type
110 type termination
Keystone type
Connector Provided
1 x RJ-45 female
