StarTech.com SFP+ Card 10 Gbps, PCIE NIC
Quicklinx: GMBNWS00 Mfr#: PEX10GSFP
Wired / Wireless: Wired
Protocol: 10 Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: [N/A]
Type: Network adapter
£124.29 ex VAT
£149.14 inc VAT
10G PCIe SFP+ Card, Single SFP+ Port Network Adapter w/ Low Profile, Open SFP+ for MSA-Compliant Modules / Direct-Attach Cables (DAC), 10 Gigabit Fiber PCIe NIC Card - PCI Express SFP+ Network Card (PEX10GSFP).
  • Increase your network speed
    This PCIe network card lets you take advantage of improved bandwidth in data-intensive applications such as multimedia streaming and large file transfers. This fiber NIC offers data transfer rates of up to 10Gbps which improve speeds and reduces load times.
  • Scalable network connection
    Featuring an open SFP+ slot, you have the flexibility to make changes as needed just by swapping the module in use, whether it is fiber, copper, or direct attach cables (DAC). The card complies with MSA, allowing use with modules from StarTech.com or 3rd parties that support MSA.
  • Enhance your existing hardware
    The 10Gb network card easily connects via an available x4 PCI Express 3.0 expansion slot. The card is shipped with a standard-profile bracket and includes a low-profile bracket for installation in various types of computer chassis. It supports a wide variety of OSes including Windows, macOS, and Linux. The PEX10GSFP is backed for 2-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 10G PCIe SFP+ Card, Single SFP+ Port Network Adapter w/ Low Profile, Open SFP+ for MSA-Compliant Modules / Direct-Attach Cables (DAC), 10 Gigabit Fiber PCIe NIC Card - PCI Express SFP+ Network Card - network adapter - PCIe x4 - 10 Gigabit SFP+ x 1
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express x4
Ports
10 Gigabit SFP+ x 1
1.8 cm x 9.4 cm x 12.1 cm
55 g
Cabling Type
Ethernet 10GBase-LR, Ethernet 10GBase-SR
10GbE
Data Transfer Rate
20 Gbps
Jumbo frame size: 9000
Aquantia AQC100S
IEEE 802.1Q, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.3aq
Network adapter
Plug-in card
PCI Express x4
Ports
10 Gigabit SFP+ x 1
Wired
Cabling Type
10 Gigabit Ethernet
Data Transfer Rate
20 Gbps
Flow control, full duplex capability, Jumbo Frames support, Link Aggregation, VLAN Tagging
Processor / Memory
Aquantia AQC100S
1 x 10GBase-LR - SFP+
Low-profile bracket
FCC, RoHS, WEEE, MSA, RCM
1.8 cm
9.4 cm
12.1 cm
55 g
Shipping Width
17 cm
Shipping Depth
14 cm
Shipping Height
3 cm
Shipping Weight
145 g
5 °C
50 °C
20 - 80% RH
GMBN StarTech.com 3m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £48.20
GMBN StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m In Stock £36.81
GMBN StarTech.com 10 Gigabit Fiber SFP+ Transceiver Module SM LC In Stock £214.57
GMBN StarTech.com 10GBase-T SFP+ - 10G Copper In Stock £157.73
