Add reliable and cost-effective 10 Gigabit Ethernet connections over copper, with this SFP+ module. This TAA compliant 10GBase-T SFP+ module delivers what you need most in your network connections: reliable performance. It's built to exacting MSA specifications and fully tested to ensure seamless compatibility. The RJ45 copper SFP+ transceiver module offers a cost-effective way to add, replace or upgrade the ports on your networking equipment.
With data transfer rates of up to 10Gbps, this SFP+ module can be installed into networking equipment with an MSA compliant port and RJ45 copper interface. It delivers dependable 10 Gigabit connectivity over copper cable, for 10GBase-T compliant networks, with a maximum distance of up to 30 m (98.4 ft.).
This SFP+ transceiver is engineered to meet or exceed the industry's MSA (Multi-Source Agreement) standards. StarTech.com brings its established reputation for high-quality connectivity solutions to SFP transceivers, providing SFPs that match major OEM brands in performance and reliability. Committed to the highest standards, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
Delivering both convenience and scalability, this transceiver module is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile solution that's compatible with a wide range of networking equipment, allowing you to expand your network to remote segments cost-effectively.
StarTech.com SFPs
All StarTech.com SFP & SFP+ transceiver modules are backed by a lifetime warranty and free lifetime multilingual technical support. StarTech.com offers a wide variety of SFP modules and direct-attach SFP Cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com MSA Uncoded Compatible SFP+ Module, 10GBASE-T, SFP to RJ45 (Copper) for Cat6 and Cat5e, 10GE Gigabit Ethernet SFP+, RJ-45 (Copper) 30m, 10Gbps Transceiver SFP+ Copper Module - Lifetime Warranty (SFP10GBTST) - SFP+ transceiver module - 10GbE - TAA Compliant
- SFP+ transceiver module - RJ-45
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-X, 10GBase-T
- Data Transfer Rate
- 10 Gbps
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 30 m
- 1.39 cm x 5.84 cm x 1.26 cm
- 30 g
- TAA Compliant
- Limited lifetime warranty
- Designed For
- P/N: PEX10GSFP
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 10GbE
- 10 Gbps
- 30 m
- Full duplex capability
- IEEE 802.3an
- 1 x Ethernet 10GBase-T - SFP+ female
- FCC, RoHS, WEEE, MSA, RCM
- TAA Compliant
- 1.39 cm
- 5.84 cm
- 1.26 cm
- 30 g
- Limited warranty - lifetime
- 0 °C
- 70 °C
- 5 - 95%
- Designed For
- P/N: PEX10GSFP
