10G PCIe SFP+ Card, Single SFP+ Port Network Adapter w/ Low Profile, Open SFP+ for MSA-Compliant Modules / Direct-Attach Cables (DAC), 10 Gigabit Fiber PCIe NIC Card - PCI Express SFP+ Network Card (PEX10GSFP).
Increase your network speed
This PCIe network card lets you take advantage of improved bandwidth in data-intensive applications such as multimedia streaming and large file transfers. This fiber NIC offers data transfer rates of up to 10Gbps which improve speeds and reduces load times. -
Scalable network connection
Featuring an open SFP+ slot, you have the flexibility to make changes as needed just by swapping the module in use, whether it is fiber, copper, or direct attach cables (DAC). The card complies with MSA, allowing use with modules from StarTech.com or 3rd parties that support MSA. -
Enhance your existing hardware
The 10Gb network card easily connects via an available x4 PCI Express 3.0 expansion slot. The card is shipped with a standard-profile bracket and includes a low-profile bracket for installation in various types of computer chassis. It supports a wide variety of OSes including Windows, macOS, and Linux. The PEX10GSFP is backed for 2-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com 10G PCIe SFP+ Card, Single SFP+ Port Network Adapter w/ Low Profile, Open SFP+ for MSA-Compliant Modules / Direct-Attach Cables (DAC), 10 Gigabit Fiber PCIe NIC Card - PCI Express SFP+ Network Card - network adapter - PCIe x4 - 10 Gigabit SFP+ x 1
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x4
- Ports
- 1.8 cm x 9.4 cm x 12.1 cm
- 55 g
- Cabling Type
- Ethernet 10GBase-LR, Ethernet 10GBase-SR
- Data Link Protocol
- 10GbE
- Data Transfer Rate
- 20 Gbps
- Capacity
- Jumbo frame size: 9000
- Processor
- Aquantia AQC100S
- IEEE 802.1Q, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.3aq
- 2-year warranty
- Network adapter
- Form Factor
- Plug-in card
- PCI Express x4
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 10 Gigabit Ethernet
- 20 Gbps
- Capacity
- Flow control, full duplex capability, Jumbo Frames support, Link Aggregation, VLAN Tagging
Processor / Memory
- Processor
- Aquantia AQC100S
- 1 x 10GBase-LR - SFP+
- Included Accessories
- Low-profile bracket
- FCC, RoHS, WEEE, MSA, RCM
- 1.8 cm
- 9.4 cm
- 12.1 cm
- 55 g
- Shipping Width
- 17 cm
- Shipping Depth
- 14 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 145 g
- Limited warranty - 2 years
- 5 °C
- 50 °C
- 20 - 80% RH
StarTech.com 3m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable | In Stock | £46.24 |
StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m | In Stock | £35.41 |
StarTech.com 10 Gigabit Fiber SFP+ Transceiver Module SM LC | In Stock | £213.98 |
StarTech.com 10GBase-T SFP+ - 10G Copper | In Stock | £153.91 |
