Count on maximum cost-savings and dependable Gigabit Ethernet connections with this bulk pack of single-mode / multi-mode Mini-GBIC modules. Ideal for large-scale deployments or installations on multiple devices, this bulk pack of HP compatible Gigabit fiber SFPs is engineered by StarTech.com to deliver reliability and maximum cost savings. Built to exacting specifications and fully tested to ensure maximum performance, these high-quality transceiver modules can be installed into HP networking devices that support the J4859C transceiver module, as well as other major brands of networking equipment.
These 1000Base-LX SFPs deliver Gigabit connectivity over single-mode or multimode fiber cable. The SFP transceivers provide a dependable and cost-effective way to add, replace or upgrade the Gigabit fiber ports on your networking equipment.
The SFP transceivers included in this 10-pack are manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com produces an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
These Gigabit SM/MM SFPs are engineered to the highest quality standards and are 100% HP compatible, equivalent to the HP J4859C mini-GBIC. StarTech.com SFP transceivers are configured and fully tested to ensure they work seamlessly with HP or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, these Gigabit fiber transceivers are fully hot-pluggable which enables you to install them without interrupting network traffic or having to reboot your equipment. They provide a versatile and cost-effective solution that's compatible with a multitude of Gigabit fiber networking devices.
Ideal for use in HP switches, routers and other networking equipment, the SFPs provide reliable performance, enabling you to expand your network to remote segments cost-effectively. The SFPs support Digital Diagnostics Monitoring (DDM) and both single-mode (with maximum distance of 10 km or 6.2 mi.) and multimode (with a maximum distance of 550 m or 1804 ft.). They provide maximum data rates of up to 1.25Gbps.
- StarTech.com 10 pack HPE J4859C Compatible SFP Module, 1000BASE-LX, 1GbE Single Mode SMF/MMF Optic Transceiver, 1 Gigabit Ethernet, LC Connector 10km, 1310nm DDM, HPE 1400 1700, Mini GBIC - Lifetime Warranty (J4859C10PKST) - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - LC
- Packaged Quantity
- 10 (specifications are for single item)
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-LX
- Data Transfer Rate
- 1.25 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 10 km
- OEM Manufacturer Equivalent Part Number
- HP J4859C
- 1.3 cm x 5.7 cm x 1.4 cm
- Limited lifetime warranty
- Designed For
- HPE 1700, 1810, 1910, 20p 10/100/1000, 2610, 2810, 3500, 42XX, 6200, 93XX, EDGE Fabric Switch 81XX, Switch 1800-24, Switch 26XX, Switch 2900-24, Switch 2900-48, Switch 5406, Switch 8212, Switch vl 4-port, Switch XL 10/100/1000, V1400, vl 20; HPE Aruba 2530, 2930F 24, 2930F 48, 5406, Switch 5400zl 24
- Packaged Quantity
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-LX
- 1GbE
- 1.25 Gbps
- 1310 nm
- 10 km
- Full duplex capability, Digital Diagnostics Monitoring (DDM)
- IEEE 802.3z
- 1 x Ethernet 1000Base-LX - LC x 2
- UL, FCC, RoHS, MSA
- HP J4859C
- 1.3 cm
- 5.7 cm
- 1.4 cm
- Limited warranty - lifetime
- 0 °C
- 70 °C
- 30 - 75%
- Designed For
- HP 9400sl 40-Port Mini-GBIC Module, EP Redundant Management Module, Switch 2510-24, Switch 5406zl-48G Intelligent Edge, Switch 5412zl Intelligent Edge, Switch 5412zl-96G Intelligent Edge , HPE 1700-24 Switch, 1810-24 v2, 1810-8 v2, 1910-8G Switch, 1910-8G-PoE+ (180W) Switch, 1910-8G-PoE+ (65W) Switch, 20p 10/100/1000 + 4p Mini-GBIC Module, 2610-24 Switch, 2610-24-PoE Switch, 2610-24-PPoE Switch, 2610-48 Switch, 2610-48-PoE Switch, 2810-24G Switch, 2810-48G Switch, 3500-24G-PoE yl Switch, 3500-48G-PoE yl Switch, 4202-72 vl Switch, 4204 vl Switch, 4204-44G-4SFP vl Switch, 4208 vl Switch, 4208-68G-4SFP vl Switch, 4208-96 vl Switch, 6200-24G-mGBIC yl Switch, 9304M, 9308M, 9315M, EDGE Fabric Switch 8108fl, EDGE Fabric Switch 8116fl, Switch 1800-24G, Switch 2600-8-PWR, Switch 2626, Switch 2626-PWR, Switch 2650, Switch 2650-PWR, Switch 2824, Switch 2848, Switch 2900-24G, Switch 2900-48G, Switch 3400cl-24G, Switch 3400cl-48G, Switch 4140gl, Switch 4160gl, Switch 5304XL-32G, Switch 5308xl, Switch 5308XL-48G, Switch 5348 XL-G, Switch 5348xl, Switch 5372xl, Switch 5406zl Intelligent Edge, Switch 6108, Switch 8212zl, Switch fl 10-Port Mini-GBIC Interface Module, Switch gl 10/100/1000 Module, Switch gl Mini-GBIC Module, Switch vl 4-port Mini-GBIC Module, Switch XL 10/100/1000 Module, Switch xl Mini-GBIC Module, V1400-24G Switch, vl 20p Gig-T+ 4P SFP module switch , HPE Aruba 2530-24G, 2530-24G-PoE+, 2530-48G, 2530-48G-PoE+, 2530-48-PoE+, 2930F 24G 4SFP, 2930F 24G 4SFP+, 2930F 24G PoE+ 4SFP, 2930F 48G 4SFP, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP, 2930F 48G PoE+ 4SFP+, 5406 zl, Switch 5400zl 24p Mini-GBIC Module
StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £16.62 |
StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £26.96 |
StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £17.27 |
StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £22.07 |
StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £19.16 |
StarTech.com 7m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £24.91 |
StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £26.47 |
StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £20.05 |
StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £22.05 |
StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC | In Stock | £159.80 |
StarTech.com Fiber Media Converter - Open | In Stock | £47.96 |
StarTech.com SFP - HP J4858C Comp. 10 Pack | In Stock | £246.33 |
StarTech.com SFP - HP J4859C Comp. 10 Pack | In Stock | £288.28 |
StarTech.com SFP - HP J4858C Compatible | In Stock | £37.94 |
StarTech.com Gb RJ45 SFP - HP Compatible | In Stock | £36.29 |
StarTech.com SFP+ - HP J9151A Compatible | In Stock | £170.26 |
StarTech.com SFP+ - HP JD092B Compatible | In Stock | £132.79 |
StarTech.com SFP - HP J4859C Compatible | In Stock | £43.91 |
StarTech.com Gb Copper SFP HP 453154-B21 Compatible | In Stock | £56.53 |
StarTech.com 10 Gb SFP+ HP 455883-B21 Compatible | In Stock | £253.73 |
StarTech.com HP JD089B Compatible SFP | In Stock | £39.58 |
StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports | In Stock | £367.18 |
