Ensure dependable 10Gb Ethernet connections and cost-savings with this single-mode Mini-GBIC module. This HP compatible 10 Gigabit fiber SFP+ is engineered by StarTech.com to deliver what you want most in your network connections: reliability. Built to exacting specifications and fully tested to ensure maximum performance, you can install this high-quality fiber transceiver module into HP networking devices that support the J9151A transceiver module, as well as other major brands of networking equipment.
This 10GBase-LR SFP+ delivers 10 Gigabit connectivity over single-mode fiber cable with a range of up to 10 km (6.2 mi.). It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment.
This 10 GbE SFP+ is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
This 10 Gigabit single-mode SFP+ is engineered to the highest quality standards and is 100% HP compatible, equivalent to the HP J9151A SFP+ transceiver. The StarTech.com SFP+ transceiver module is configured and fully tested to ensure it works seamlessly with HP or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber SFP+ transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a wide range of 10 Gigabit networking devices.
Ideal for use in HP switches, routers and other networking equipment, the SFP+ optical transceiver provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The SM fiber transceiver module supports Digital Diagnostics Monitoring (DDM), a maximum distance of up to 10 km (6.2 mi.), and maximum data rates of up to 10Gbps.
- StarTech.com 10 Gb Fiber SFP+ - HP J9151A Compatible - SM LC -10km/6.2 mi - Lifetime Warranty (J9151AST) - SFP+ transceiver module - 10Mb LAN, 100Mb LAN, 1GbE, 10GbE
- SFP+ transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-LR
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- Max Transfer Distance
- 10 km
- OEM Manufacturer Equivalent Part Number
- HP J9151A
- 1.3 cm x 5.7 cm x 1.4 cm
- Limited lifetime warranty
- Designed For
- HP SFP+ zl Module Rack Shippable; HPE 2-Port SFP+/ 2-Port CX4 10GbE yl Module, 6120XG Blade Switch, 6600-24G-4XG Switch, 6600-48G-4XG Switch, SFP+ zl; HPE Aruba 2930F 24G 4SFP+, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP+, 5406 zl
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-LR
- 10 Gbps
- 1310 nm
- 10 km
- Full duplex capability, Digital Diagnostics Monitoring (DDM)
- IEEE 802.3ae
- 1 x Ethernet 10GBase-LR - LC single-mode x 2
- UL, FCC, RoHS, MSA
- HP J9151A
- 1.3 cm
- 5.7 cm
- 1.4 cm
- Limited warranty - lifetime
- 0 °C
- 70 °C
- 30 - 75%
- Designed For
- HP SFP+ zl Module Rack Shippable , HPE 2-Port SFP+/ 2-Port CX4 10GbE yl Module, 6120XG Blade Switch, 6600-24G-4XG Switch, 6600-48G-4XG Switch, SFP+ zl , HPE Aruba 2930F 24G 4SFP+, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP+, 5406 zl
StarTech.com 2-Port 10G Fiber NIC-Open SFP+ | In Stock | £295.64 |
StarTech.com SFP - HP J4858C Comp. 10 Pack | In Stock | £227.46 |
StarTech.com SFP - HP J4859C Comp. 10 Pack | In Stock | £234.81 |
StarTech.com SFP - HP J4858C Compatible | In Stock | £36.15 |
StarTech.com Gb RJ45 SFP - HP Compatible | In Stock | £34.35 |
StarTech.com SFP+ - HP J9151A Compatible | In Stock | £159.76 |
StarTech.com SFP+ - HP JD092B Compatible | In Stock | £126.48 |
StarTech.com SFP - HP J4859C Compatible | In Stock | £40.56 |
StarTech.com Gb Copper SFP HP 453154-B21 Compatible | In Stock | £30.29 |
StarTech.com 10 Gb SFP+ HP 455883-B21 Compatible | In Stock | £221.15 |
StarTech.com HP JD089B Compatible SFP | In Stock | £37.43 |
