Get reliable Gigabit Ethernet connections at maximum cost-savings with this bulk pack of multi-mode Mini-GBIC modules. Ideal for large-scale deployments or installations on multiple devices, this bulk pack of HP compatible Gigabit fiber SFPs is engineered by StarTech.com to deliver reliability and maximum cost savings. Built to exacting specifications and fully tested to ensure maximum performance, these high-quality transceiver modules can be installed into HP networking devices that support the J4858C transceiver module, as well as other major brands of networking equipment.
These 1000Base-SX SFPs deliver Gigabit connectivity over multimode fiber cable with a range of up to 550 m (1804 ft.). The SFP transceivers provide a dependable and cost-effective way to add, replace or upgrade the Gigabit fiber ports on your networking equipment.
The Gigabit SFP transceivers included in this 10-pack are manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com produces an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
These Gigabit multimode SFPs are engineered to the highest quality standards and are 100% HP compatible, equivalent to the HP J4858C mini-GBIC. StarTech.com SFP transceivers are configured and fully tested to ensure they work seamlessly with HP or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, these Gigabit fiber transceivers are fully hot-pluggable, which enables you to install them without interrupting network traffic or having to reboot your equipment. They provide a versatile and cost-effective solution that's compatible with a wide range of Gigabit fiber networking devices.
Ideal for use in HP switches, routers and other networking equipment, the SFPs provide reliable performance, enabling you to expand your network to remote segments cost-effectively. The SFP transceivers support multimode fiber cable with a maximum distance of 550 m or 1804 ft., and maximum data rates of up to 1.25Gbps. The GbE fiber SFPs also support Digital Diagnostics Monitoring (DDM).
- StarTech.com 10 pack HPE J4858C Compatible SFP Module, 1000BASE-SX, 1GbE Multi Mode (MMF) Fiber Optic Transceiver, 1 Gigabit Ethernet SFP, LC Connector, 550m, 850nm, DDM, HPE 1400, 1700, 1820 - Lifetime Warranty (J4858C10PKST) - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - LC multi-mode
- Packaged Quantity
- 10 (specifications are for single item)
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-SX
- Data Transfer Rate
- 1.25 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 550 m
- OEM Manufacturer Equivalent Part Number
- HP J4858C
- Limited lifetime warranty
- Designed For
- HP Switch 2910al-24, Switch 2910al-48; HPE 1700, 1810, 1910, 20p 10/100/1000, 2610, 2810, 2910, 3500, 6120, 6200, 6600, Switch 1800-24, Switch 2900-24, Switch 2900-48, Switch 8212, Switch vl 4-port, Switch XL 10/100/1000, V1400, vl 20; HPE Aruba 2530, 2930F 24, 2930F 48, 5406, Switch 5400zl 24
- Packaged Quantity
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-SX
- 1GbE
- 1.25 Gbps
- 850 nm
- 550 m
- Full duplex capability, half duplex mode, Digital Diagnostics Monitoring (DDM)
- IEEE 802.3z
- 1 x Ethernet 1000Base-SX - LC multi-mode x 2
- UL, FCC, RoHS, MSA
- HP J4858C
- Limited warranty - lifetime
- 0 °C
- 70 °C
- 30 - 75%
- Designed For
- HP 9400sl 40-Port Mini-GBIC Module, EP Redundant Management Module, Switch 2510-24, Switch 2510-48, Switch 2510G-24, Switch 2510G-48, Switch 2610-24, Switch 2610-24/12-PWR, Switch 2610-24-PWR, Switch 2610-48, Switch 2610-48-PWR, Switch 2910al-24G-PWR, Switch 2910al-48G-PWR , HPE 1700-24 Switch, 1810-24 v2, 1810-24G Switch, 1810-8 v2, 1910-8G Switch, 1910-8G-PoE+ (180W) Switch, 1910-8G-PoE+ (65W) Switch, 20p 10/100/1000 + 4p Mini-GBIC Module, 2610-24 Switch, 2610-24-PoE Switch, 2610-24-PPoE Switch, 2610-48 Switch, 2610-48-PoE Switch, 2810-24G Switch, 2810-48G Switch, 2910-24G al Switch, 2910-24G-PoE+ al Switch, 2910-48G al Switch, 2910-48G-PoE+ al Switch, 3500-24G-PoE yl Switch, 3500-48G-PoE yl Switch, 6120XG Blade Switch, 6200-24G-mGBIC yl Switch, 6600-24G, 6600-24G-4XG Switch, 6600-48G, 6600-48G-4XG Switch, Switch 1800-24G, Switch 2600-8-PWR, Switch 2626, Switch 2626-PWR, Switch 2650, Switch 2650-PWR, Switch 2824, Switch 2848, Switch 2900-24G, Switch 2900-48G, Switch 3400cl-24G, Switch 3400cl-48G, Switch 6108, Switch 8212zl, Switch fl 10-Port Mini-GBIC Interface Module, Switch gl 10/100/1000 Module, Switch gl Mini-GBIC Module, Switch vl 4-port Mini-GBIC Module, Switch XL 10/100/1000 Module, Switch xl Mini-GBIC Module, V1400-24G Switch, vl 20p Gig-T+ 4P SFP module switch , HPE Aruba 2530-24G, 2530-24G-PoE+, 2530-48G, 2530-48G-PoE+, 2530-48-PoE+, 2930F 24G 4SFP, 2930F 24G 4SFP+, 2930F 24G PoE+ 4SFP, 2930F 48G 4SFP, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP, 2930F 48G PoE+ 4SFP+, 5406 zl, Switch 5400zl 24p Mini-GBIC Module
StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £16.62 |
StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £26.96 |
StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £17.27 |
StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £22.07 |
StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £19.16 |
StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC | In Stock | £159.80 |
StarTech.com Fiber Media Converter - Open | In Stock | £47.96 |
StarTech.com SFP - HP J4858C Comp. 10 Pack | In Stock | £246.33 |
StarTech.com SFP - HP J4859C Comp. 10 Pack | In Stock | £293.64 |
StarTech.com SFP - HP J4858C Compatible | In Stock | £37.35 |
StarTech.com Gb RJ45 SFP - HP Compatible | In Stock | £36.29 |
StarTech.com SFP+ - HP J9151A Compatible | In Stock | £173.42 |
StarTech.com SFP+ - HP JD092B Compatible | In Stock | £132.79 |
StarTech.com SFP - HP J4859C Compatible | In Stock | £43.91 |
StarTech.com Gb Copper SFP HP 453154-B21 Compatible | In Stock | £56.53 |
StarTech.com 10 Gb SFP+ HP 455883-B21 Compatible | In Stock | £253.73 |
StarTech.com HP JD089B Compatible SFP | In Stock | £39.58 |
StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports | In Stock | £367.18 |
