StarTech.com SFP+ - HP JD092B Compatible
Quicklinx: C583WS00 Mfr#: JD092BST
Type: Modules
£126.27 ex VAT
£151.52 inc VAT
Ensure reliable, cost-efficient 10Gb Ethernet connections over multimode fiber with this Mini-GBIC module. This HP compatible 10 Gigabit fiber SFP+ is engineered by StarTech.com to deliver what you want most in your network connections: reliability. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality fiber transceiver module can be installed into HP networking devices that support the JD092B transceiver module, as well as other major brands of networking equipment.
This 10GBase-SR SFP+ delivers 10 Gigabit connectivity over multimode fiber cable, with a range of up to 300 m (984 ft). It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment.
This 10 GbE SFP+ is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
This 10 Gigabit multimode SFP+ is engineered to the highest quality standards and is 100% HP compatible, equivalent to the HP JD092B SFP+ transceiver. The StarTech.com SFP+ is configured and fully tested to ensure it works seamlessly with HP or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber SFP+ transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a multitude of 10 Gigabit networking devices.
Ideal for use in HP switches, routers and other networking equipment, the SFP+ optical transceiver provides dependable performance, allowing you to expand your network to remote segments cost-effectively. The multimode fiber transceiver module supports Digital Diagnostics Monitoring (DDM), a maximum distance of up to 300 m (984 ft), and maximum data rates of up to 10Gbps.
StarTech.com HP JD092B Compatible SFP+ Module - Lifetime Warranty (JD092BST) - SFP+ transceiver module - 10Mb LAN, 100Mb LAN, GigE, 10 GigE
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
Max Transfer Distance
300 m
HP JD092B
1.3 cm x 5.7 cm x 1.4 cm
HP A5830AF-48G; HPE 12504, 5120-48G-PoE+, 5500-24G-PoE+-4SFP, 5500-24G-SFP, 5500-48G-4SFP, 5810-48G, 5900AF-48G-4XG-2QSFP+, 5900AF-48XG-4QSFP+, 5900AF-48XGT-4QSFP+, 5920AF-24XG; FlexFabric 1.92, 11908-V, 12902E
Plug-in module
Silver
Wired
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
300 m
Full duplex capability, Digital Diagnostics Monitoring (DDM)
IEEE 802.3ae
1 x Ethernet 10GBase-SR - LC multi-mode x 2
UL, FCC, RoHS, MSA
HP JD092B
1.3 cm
5.7 cm
1.4 cm
Limited warranty - lifetime
70 °C
30 - 75%
HP A5830AF-48G Switch , HPE 12504 AC Switch Chassis, 5120-48G-PoE+ EI Switch with 2 Interface Slots, 5500-24G-PoE+-4SFP HI Switch with 2 Interface Slots, 5500-24G-SFP HI Switch with 2 Interface Slots, 5500-48G-4SFP HI Switch with 2 interface Slots, 5810-48G Switch, 5900AF-48G-4XG-2QSFP+ Switch, 5900AF-48XG-4QSFP+ Switch, 5900AF-48XGT-4QSFP+ Switch, 5920AF-24XG Switch , HPE FlexFabric 1.92 Tbps Type D Fabric Module, 11908-V Switch Chassis, 12902E Switch Chassis
C583 StarTech.com 2m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £21.93
C583 StarTech.com 3m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £21.15
C583 StarTech.com 10m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £34.80
C583 StarTech.com 1m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £19.45
C583 StarTech.com 5m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £28.58
C583 StarTech.com SFP - HP J4858C Compatible In Stock £38.08
C583 StarTech.com SFP+ - HP JD092B Compatible In Stock £126.27
C583 StarTech.com SFP - HP J4859C Compatible In Stock £43.93
Type: Modules
