StarTech.com SFP+ - HP J9150A Compatible
Quicklinx: C584WS00 Mfr#: J9150AST
£210.96 ex VAT
£253.15 inc VAT
Ensure reliable and cost-effective 10Gb Ethernet connections over multimode fiber with this Mini-GBIC module. This HP compatible 10 Gigabit fiber SFP+ is engineered by StarTech.com to deliver what you want most in your network connections: reliability. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality fiber transceiver module can be installed into HP networking devices that support the HP J9150A transceiver module, as well as other major brands of networking equipment.
This 10GBase-SR SFP+ delivers 10 Gigabit connectivity over multimode fiber cable with a range of up to 300 m (984 ft). It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment.
This 10 GbE SFP+ is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
This 10 Gigabit multi-mode SFP+ is engineered to the highest quality standards and is 100% HP compatible, equivalent to the HP J9150A SFP+ transceiver. The StarTech.com SFP+ is configured and fully tested to ensure it works seamlessly with HP or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber SFP+ transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a wide range of 10 Gigabit networking devices.
Ideal for use in HP switches, routers and other networking equipment, the SFP+ optical transceiver provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The multimode fiber transceiver module supports Digital Diagnostics Monitoring (DDM), a maximum distance of up to 300 m (984 ft), and maximum data rates of up to 10Gbps.
StarTech.com HP J9150A Compatible SFP+ Module - Lifetime Warranty (J9150AST) - SFP+ transceiver module - 10Mb LAN, 100Mb LAN, GigE, 10 GigE
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
11.1 Gbps
Optical Wave Length
850 nm
Max Transfer Distance
300 m
HP J9150A
1.3 cm x 5.7 cm x 1.4 cm
HPE 6120XG, 6600-24G-4XG, 6600-48G-4XG; Modular Smart Array P2000 G3; ProLiant DL360p Gen8; HPE Aruba 2930F 24G, 2930F 48G, 5406
Plug-in module
Silver
Wired
Cabling Type
10GBase-SR
Data Transfer Rate
11.1 Gbps
Optical Wave Length
850 nm
300 m
Full duplex capability, Digital Diagnostics Monitoring (DDM)
IEEE 802.3ae
1 x Ethernet 10GBase-SR - LC multi-mode x 2
UL, FCC, RoHS, MSA
HP J9150A
1.3 cm
5.7 cm
1.4 cm
Limited warranty - lifetime
70 °C
30 - 75%
HPE 6120XG Blade Switch, 6600-24G-4XG Switch, 6600-48G-4XG Switch , HPE Modular Smart Array P2000 G3 10GbE iSCSI Dual Controller SFF Array System, P2000 G3 iSCSI Dual Controller SFF Bundle , HPE ProLiant DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance , HPE Aruba 2930F 24G 4SFP+, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP+, 5406 zl
C584 StarTech.com 2m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £14.49
C584 StarTech.com 3m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £20.96
C584 StarTech.com 10m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £30.27
C584 StarTech.com 1m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £16.24
C584 StarTech.com 5m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £22.49
C584 StarTech.com 2-Port 10G Fiber NIC-Open SFP+ In Stock £280.94
C584 StarTech.com SFP - HP J4858C Comp. 10 Pack In Stock £236.49
C584 StarTech.com SFP - HP J4859C Comp. 10 Pack In Stock £266.18
C584 StarTech.com SFP - HP J4858C Compatible In Stock £35.00
C584 StarTech.com SFP+ - HP J9151A Compatible In Stock £157.13
C584 StarTech.com SFP+ - HP JD092B Compatible In Stock £124.48
C584 StarTech.com SFP+ - HP J9150A Compatible In Stock £210.96
C584 StarTech.com SFP - HP J4859C Compatible In Stock £41.16
C584 StarTech.com 10GbE Fiber Media Converter In Stock £887.82
C584 StarTech.com 10 Gb SFP+ HP 455883-B21 Compatible In Stock £244.31
Stock Status: In stock
