StarTech.com Gb Copper SFP HP 453154-B21 Compatible
Quicklinx: CLVLWS00 Mfr#: 453154B21ST
Length: [N/A]
Colour: Copper
£30.85 ex VAT
£37.02 inc VAT
Count on reliable and cost-effective Gigabit Ethernet connections with this RJ45 Mini-GBIC module. This HP compatible Gigabit Copper SFP is engineered by StarTech.com to deliver what you need most in your network connections: reliable performance. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality SFP transceiver module can be installed into HP BladeSystem c-Class equipment that supports the HP 453154-B21 module, as well as other major brands of networking equipment.
This RJ45 1000Base-T SFP delivers Gigabit connectivity over a distance of up to 100 m (328 ft.). It provides a dependable and cost-effective way to add, replace or upgrade a copper Ethernet port on your networking equipment.
This Gigabit RJ45 SFP is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
This Gigabit Copper SFP is engineered to the highest quality standards and is 100% HP compatible, equivalent to the HP 453154-B21 SFP transceiver. The StarTech.com transceiver is configured and fully tested to ensure it works seamlessly with HP or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this SFP is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and convenient solution that's compatible with a multitude of multi- and single-port Gigabit Ethernet networking devices.
Ideal for use in HP BladeSystem c-Class and other compatible equipment, the SFP provides reliable performance, enabling you to expand your network to remote segments cost-effectively. The SFP supports auto-negotiation, a maximum distance of up to 100 m (328 ft.), and maximum data rates of up to 1000Mbps.
StarTech.com HPE 453154-B21 Compatible SFP Module, 1000BASE-T, SFP to RJ45 Cat6/Cat5e, 1GE Gigabit Ethernet SFP, RJ-45 (Copper) 100m, HPE 6120XG, 6120G, Flex Fabric, Mini GBIC SFP Module - Lifetime Warranty (453154B21ST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
1000Base-T
Data Transfer Rate
1 Gbps
1GbE
Max Transfer Distance
100 m
HP 453154-B21
Plug-in module
Wired
Cabling Type
1000Base-T
1GbE
Data Transfer Rate
1 Gbps
100 m
1 x Ethernet 1000Base-T - RJ-45 female
MSA
HP 453154-B21
CLVL StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £31.13
CLVL StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £139.16
CLVL StarTech.com Fiber Media Converter - Open In Stock £42.26
CLVL StarTech.com SFP - HP J4858C Comp. 10 Pack In Stock £221.91
CLVL StarTech.com SFP - HP J4859C Comp. 10 Pack In Stock £226.80
CLVL StarTech.com SFP - HP J4858C Compatible In Stock £35.83
CLVL StarTech.com Gb RJ45 SFP - HP Compatible In Stock £32.49
CLVL StarTech.com SFP+ - HP J9151A Compatible In Stock £154.31
CLVL StarTech.com SFP+ - HP JD092B Compatible In Stock £120.27
CLVL StarTech.com SFP - HP J4859C Compatible In Stock £39.58
CLVL StarTech.com Gb Copper SFP HP 453154-B21 Compatible In Stock £30.85
CLVL StarTech.com 10 Gb SFP+ HP 455883-B21 Compatible In Stock £215.75
CLVL StarTech.com HP JD089B Compatible SFP In Stock £35.41
CLVL StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £320.87
Length: [N/A]
Colour: Copper
