StarTech.com SATA III PCIe Card - 2-Port
Quicklinx: GMBHWS00 Mfr#: 2P6G-PCIE-SATA-CARD
Type: Storage controller
HD Size: [N/A]
Power Supply: [N/A]
£24.05 ex VAT
£28.86 inc VAT
This 2-port SATA III (6Gbps) controller enables you to add two SATA 6Gbps Hard Drives (HDDs) or Solid State Drives (SSDs) to your computer system or server via an available PCIe x1 card slot. The card supports SATA III and PCI-Express 2.0 Specifications.
  • ASM1061 to Deliver 2-Port SATA 6Gbps Performance
    Featuring the ASM1061 controller, this SATA card enables the connection of two high-performance SATA 6Gbps drives with a combined total throughput of up to 4Gbps. The SATA drives are connected via two individual SATA ports located on the card (SATA cables sold separately).
  • Wide Compatibility
    The controller card is widely supported across all popular operating system platforms including Windows (7, 8, 10, 11), macOS (10.6.8 and above) and Linux (2.6.32 and above). The card also supports port multiplier, giving you the ability to connect multiple drives to a single SATA port (additional hardware required, sold separately). To further improve motherboard compatibility the card does not have a built-in RAID controller, but fully supports the use of software RAID. Plus, with support for PCIe 2.0 and SATA III Specifications this card ensures backward compatibility with previous generations (SATA I/II, PCIe 1) at lower performance.
  • Hassle-Free Installation
    The SATA controller card features plug-and-play installation and can be installed in a full-profile or low-profile computer systems with the full-profile bracket preinstalled, and an interchangeable low-profile (half-height) bracket included. The card also supports storage software data management systems such as Storage Spaces (Microsoft), RAID Assistant (MacOS) and mdraid/mdadm (Linux), for hassle-free setup, partitioning and software RAID array building. 2P6G-PCIE-SATA-CARD is backed by a StarTech.com lifetime warranty and free lifetime 24/5 North American based, multi-lingual support.
StarTech.com SATA PCIe Card, 2 Port PCIe SATA Expansion card, 6Gbps SATA Card, Full/Low Profile, PCI Express to SATA Adapter, ASM1061 Non-Raid SATA Controller Card - PCIe to SATA Converter - storage controller - SATA 6Gb/s - PCIe 2.0 x1
Storage controller - plug-in card - low profile
Bus Type
PCIe 2.0 x1
Red
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Channel Qty
2
Max Storage Devices Qty
2
Microsoft Windows Vista / XP, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.6.8 or later, Linux 2.6.32 or later
1.8 cm x 12.1 cm x 6.9 cm
33 g
Host Bus
PCIe 2.0 x1
Red
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Channel Qty
2
2
ASMedia ASM1061
2 x SATA 6Gb/s - SATA (internal)
Low-profile bracket, full-height bracket
Support port multiplier, S.M.A.R.T. support, TRIM support, 4Kn drive compatible, bootable, hdd led pin header, ATAPI support
Plug and Play, WEEE, RCM
Limited warranty - lifetime
1.8 cm
12.1 cm
6.9 cm
33 g
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
110 g
85 °C
20 - 80% RH
GMBH StarTech.com 24" Serial ATA Cable In Stock £5.28
GMBH StarTech.com 18in SATA Serial ATA Cable In Stock £2.41
GMBH StarTech.com 36in SATA Serial ATA Cable In Stock £5.70
GMBH StarTech.com 12in Latching SATA Cable In Stock £6.16
GMBH StarTech.com 18in Latching SATA Cable In Stock £4.24
GMBH StarTech.com 24in Latching SATA Cable In Stock £6.84
GMBH StarTech.com 6in SATA Serial ATA Cable In Stock £3.61
GMBH StarTech.com 12in SATA Serial ATA Cable In Stock £5.00
GMBH StarTech.com 6in Latching SATA Cable In Stock £2.60
GMBH StarTech.com 8in Latching SATA to SATA Cable - F/F In Stock £5.44
HD Size: [N/A]
Power Supply: [N/A]
