The R-Port Serial Remote Control module offers a unique way to expand the capability of your Server Remote Control device or Digital KVM switch.
All configuration settings are stored separately in each attached device in nonvolatile memory so that they will not be lost in the event of a power outage or disconnection.
Control your serial devices - routers, managed switches, printers, or even serial console based Linux servers - as if you were right there in the room with them.
Daisy-chain up to 16 R-Port devices, and control them all using an interactive Web interface! To minimize your space and infrastructure requirements, the R-Port devices use a single cable to carry both power and data.
StarTech.com's Server Remote Control products allow you the flexibility to control your device locally via console, or remotely via the network or the public Internet. You choose the best way to work with your devices!
- StarTech.com R-Port Serial Remote Control Module - serial adapter
- Serial adapter
- Form Factor
- External
- Data Link Protocol
- Serial
- 2-year warranty
- Designed For
- P/N: CABCONS1716I, SV441DUSBI, SV841HDIE, SV841HDIEGB
- Serial adapter
- Form Factor
- External
- Connectivity Technology
- Wired
- Serial
- 1 x serial - 9 pin D-Sub (DB-9)
- Connections
- 2 x serial - RJ-14
- Limited warranty - 2 years
- Designed For
