StarTech.com Removable 2.5" SATA HDD Enclosure/Backup System/Mobile Rack for 3.5/5.25" Bay
Quicklinx: 8JFHWS00 Mfr#: SAT2510U3REM
  • Windows 8 (32/64 bits)
Turn a 2.5in SATA drive into a front bay mounted removable HDD backup solution. The SAT2510U3REM Removable 2.5" SATA HDD Backup System/Mobile Rack turns a 2.5" SATA HDD/SSD drive into a removable hard drive that can also be used externally as a normal USB 3.0 enclosure.
This 2.5" SATA removable hard drive bay can be mounted into any 3.5" or 5.25" front bay, to provide a hot-swap capable mobile rack. Drives can then be easily installed and removed from the computer system without having to open the computer case every time, providing a convenient method of creating backups that can then be removed for safe keeping/archiving.
When outside of the drive bay, the enclosure can be used as a standard external USB 3.0 hard drive with up to 5 Gbps of data transfer bandwidth (10x more than USB 2.0). This makes the removable 2.5" hard drive bay an excellent accessory for people working with very large files and need to take them on the road.
For even more versatility, StarTech.com offers the SAT2510U3S, an extra 2.5in SATA Hard Drive Enclosure for the SAT2510U3REM, providing multiple enclosures that can be swapped in and out of the main computer. The SAT2510U3REM is also backward compatible with the USB 2.0 model, SAT2510U2S.
StarTech.com Removable 2.5" SATA HDD Backup System for 3.5/5.25" Bay - storage mobile rack - USB 3.0 / SATA 6Gb/s - SATA 6Gb/s, USB 3.0
Storage mobile rack
Bus Type
SATA 6Gb/s, USB 3.0
Expansion Bays
1 x internal - 2.5" x 1/8H , 1 x front accessible - 5.25"/ 3.5" shared
Compatible Bay
1 5.25" , 1 3.5"
Hard Drive Form Factor Compatibility
2.5"
Supported Interface
SATA-600
Drive Connector
22 pin Serial ATA
Bay Connector
7 pin Serial ATA
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
1
Product Material
Plastic, aluminium
Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
14.58 cm x 16.48 cm x 4.16 cm
410 g
P/N: S251BU31REMD
Storage mobile rack
2.5"
Host Bus
SATA 6Gb/s, USB 3.0
Product Material
Plastic, aluminium
Supported Interface
SATA-600
Storage Controller
Data Transfer Rate
6 Gbit/s
Supported Devices
1
ASMedia ASM1053 / ASM1456
Bays
1 x SATA 6Gb/s - SATA combo , 1 x - Micro-USB Type B
1 x USB 3.0 - 9 pin USB Type A , 1 storage - Serial ATA-600 - 7 pin Serial ATA
Compatible Bay
1 x external 5.25" , 1 x external 3.5"
3.5" bay adapter, 5.25" bay adaptor
1 x USB 3.0 cable , 1 x Serial ATA cable , 1 x power 15 pin SATA to 4 pin adapter , 1 x floppy adapter
Mounting Kit
Included
FCC, RoHS
14.58 cm
16.48 cm
4.16 cm
410 g
5 - 95%
P/N: S251BU31REMD
