StarTech.com Rackmount KVM Console - 16 Ports with 17" LCD Monitor
Quicklinx: F2GKWS00 Mfr#: RKCONS1716K
Type: KVM switch
Ports: 16
Connectivity: KVM
Hurry, only 2 left in stock!
£1,083.73 ex VAT
£1,300.47 inc VAT
Providing centralized control of up to 16 servers, this 16-port rackmount KVM console gives you easy access to your systems. With a minimal footprint, it mounts in a server rack or cabinet using only 1U of rack space.
The 1U rackmount console features a built-in keyboard, and a touchpad for intuitive control, as well as a 17-inch LCD display that supports resolutions up to 1280x1024.
This 16-port KVM console comes with everything you need to set up right out of the box: 16 VGA KVM Cables; Mounting Rails; M5 Cage Nuts and Screws.
With direct access to 16 systems or servers, the 16-port KVM module gives you the flexibility you need to easily integrate the console into your existing server infrastructure.
Rack consoles provide convenient, rack-mounted control options for single servers or the entire server room. KVM consoles include LCD display, keyboard, and trackpad, all sliding into 1U of rack space.
  • Efficient space-saving design
    The rack-mountable form factor allows for easy installation in standard 1U racks, helping to optimize workspace and keep environments organized.
  • High-quality display performance
    Featuring a diagonal size of 17 inches and a contrast ratio of 1000:1, the display provides clear, sharp images and supports 16.7 million colors for vibrant visuals.
  • Robust connectivity options
    The KVM console supports a range of connections including USB 2.0 and PS/2, ensuring compatibility with various devices and systems for versatile use.
  • Reliable operational longevity
    Boasting a mean time between failures (MTBF) of 50,000 hours, this console is built for durability and consistent performance in demanding environments.
StarTech.com 16 Port Rackmount KVM Console w/ Cables - Integrated KVM Switch w/ 17" LCD - 1U LCD KVM Drawer 50000 MTBF - USB + VGA Support (RKCONS1716K) - KVM console - 17"
KVM console - 17"
KVM Switch
PS/2, USB - 16 ports
Keyboard, touchpad, 16 port KVM switch
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
16.7 million colours
Input Connectors
VGA
Voltage
AC 120/230 V
44.8 cm x 58.1 cm x 4.25 cm
Height (Rack Units)
1U
13.7 kg
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
Display Type
KVM console / TFT active matrix
Diagonal Size
17"
Built-in Devices
16 port KVM switch
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Height (Rack Units)
1U
13.7 kg
Input
Keyboard, touchpad
KVM
KVM switch - 16 ports
Keyboard / Mouse Interface
PS/2, USB
Max Resolution
1280 x 1024 @ 60 Hz
16 x VGA , 2 x USB 2.0 (Type A) , 2 x PS/2 , VGA output , Daisy chain port (HD-15)
8 x M5 cage nuts, 8 x M5 screws, 2 x mounting rails
16 x keyboard / mouse / video cable - 1.83 m
Rack Mounting Kit
Included
MTBF
50,000 hour(s)
Input Voltage
AC 120/230 V
Power Consumption (Typical)
23 Watt
Shipping Weight
21 kg
10 - 80% (non-condensing)
F2GK StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
F2GK StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.20
F2GK StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.24
F2GK StarTech.com 19in Cable Management Panel In Stock £23.58
F2GK StarTech.com 8 Port KVM Console for Server Rack - 19in In Stock £1,152.52
F2GK StarTech.com Single Server KVM Console for Server Rack -19" In Stock £730.86
F2GK StarTech.com 16 port KVM VGA Console with KVM Switch - 19" In Stock £1,308.69
F2GK StarTech.com 17" Dual Rail Rackmount KVM Console with 1080p In Stock £904.75
F2GK StarTech.com Rackmount KVM Console - 16 Ports with 17" LCD Monitor In Stock £1,083.73
F2GK StarTech.com 1U HD Single Server KVM In Stock £783.87
F2GK StarTech.com 10 ft. (3 m) USB KVM Cable for Rackmount Consoles In Stock £29.38
F2GK StarTech.com 15 ft. (4.6 m) USB KVM Cable for Rackmount Consoles In Stock £39.35
F2GK StarTech.com 6 ft. (1.8 m) USB KVM Cable for Rackmount Consoles In Stock £17.16
Type: KVM switch
Ports: 16
Connectivity: KVM
Price Range Ex VAT: £1000 - £1500
