StarTech.com Professional Multi Function RJ45 RJ11 USB and BNC Cable Test
Quicklinx: FSHXWS00 Mfr#: REMOTETEST
Hurry, only 3 left in stock!
£92.55 ex VAT
£111.06 inc VAT
Troubleshoot your wiring problems, quickly and affordably with StarTech.com's REMOTETEST, a specially designed network wire tester that saves valuable time and effort when testing RJ45, RJ11 and BNC cables.
  • Versatile connectivity
    Equipped with a wide range of connectors including 4-pin USB Type-A, 4-pin USB Type-B, BNC, RJ-11, and RJ-45, this device ensures compatibility with a variety of cable types, making it a valuable tool for professionals.
  • Comprehensive testing capabilities
    This network tester is designed to efficiently identify issues with your cables, offering tests for opens and shorts. Its compatibility with copper media makes it a valuable tool for troubleshooting network problems.
StarTech.com Professional Multi Function RJ45 RJ11 USB and BNC Cable Tester - network tester
Network tester
Tests, Tools and Measurements
Tests for shorts, tests for opens
11 cm x 18 cm x 2.5 cm
250 g
2 years
Network tester
Media
Copper
Soft case
Connectors
BNC, RJ-45 x 2, 4 pin USB type A, 4 pin USB type B, RJ-11 x 2
RoHS
Warranty
2 years
Alkaline
Voltage
9 V
Included Qty
1
Required Qty
1
11 cm
18 cm
2.5 cm
250 g
FSHX StarTech.com 1000 ft Bulk Roll of Blue CMR Cat 6 Solid UTP Riser Cable In Stock £298.07
FSHX StarTech.com 1000 ft Bulk Roll of Gray CMR Cat 6 Solid UTP Riser Cable In Stock £305.44
FSHX StarTech.com 1000ft Cat6 Ethernet Cable CMR In Stock £305.44
FSHX StarTech.com 20-Bit Electric Precision Screwdriver Set In Stock £43.02
FSHX StarTech.com 55-Bit Electric Precision Screwdriver Set In Stock £59.62
FSHX StarTech.com Temperature/Humidity Meter In Stock £24.99
FSHX StarTech.com Handheld Sound Level Meter In Stock £25.95
