StarTech.com 1000ft Cat6 Ethernet Cable CMR
Quicklinx: D38DWS00 Mfr#: WIR6CMRBK
Length: 304.9m
Colour: Black
Colours:
£311.35 ex VAT
£373.62 inc VAT
Make Gigabit Ethernet connections with PoE support, in applications requiring CMR-rated cable. This bulk Cat6 cable delivers reliable Gigabit network connections, which ensures high-performance capability for your demanding Ethernet applications. The Cat6 cable is riser rated for in-wall installations.
This Category 6 cable has been tested for CMR riser installations, and is ideal for in-wall, between floor and elevator shaft cable runs where CMR fire rating is required.
Each of the cables is manufactured using high-quality copper conductors and they are carefully constructed and tested, to keep Near-End Crosstalk (NEXT) well within acceptable limits.
Ensure high-performance capability for your demanding Ethernet applications, such as Power-over-Ethernet and 4K or 1080p video streaming, using cables that include 23 AWG copper.
StarTech.com 1000 ft Bulk Roll of Black CMR Cat6 Solid UTP Riser Cable - Cat 6 Riser Cable - Cat.6 CMR Ethernet Cable - 23 AWG - Black (WIR6CMRBK) - bulk cable - 304.9 m - black
Bulk cable - CAT 6
Unshielded twisted pair (UTP)
Riser, solid, minimised Near-End Crosstalk (NEXT)
Length
304.9 m
Network Cable Type
Bulk cable - CAT 6
Jacket Material
PVC
American Wire Gauge (AWG)
23
Length
304.9 m
UL, RoHS, ETL, WEEE, CMP - up to 550 MHz
D38D StarTech.com Solid Wire Cat 6 Modular Plug In Stock £15.17
Length: 304.9m
Colour: Black
