StarTech.com 1000 ft Bulk Roll of Gray CMR Cat 6 Solid UTP Riser Cable
Quicklinx: 91F7WS00 Mfr#: WIR6CMRGR
Length: 304.9m
Colour: Grey
Colours:
Hurry, only 1 left in stock!
£305.44 ex VAT
£366.52 inc VAT
The WIR6CMRGR 1000 ft Cat6 Riser Bulk Cable roll (gray) meets or exceeds all Category 6 specifications to ensure reliable Gigabit network connections, and features a foot-marked jacket that makes it easy to tell how much cable is left on the roll and enables you to measure your cable runs to your exact installation requirements.
This Category 6 cable has been tested for CMR riser installations, and is ideal for in-wall, between floor and elevator shaft cable runs where CMR fire rating is required.
StarTech.com Cat6 cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable, based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
This Cat6 cable is constructed with 23 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, StarTech.com cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
StarTech.com 1000 ft Bulk Roll of Gray CMR Cat6 Solid UTP Riser Cable - Cat 6 Riser Cable - Cat.6 CMR Ethernet Cable - 23 AWG - Gray (WIR6CMRGR) - bulk cable - 304.9 m - grey
Bulk cable - CAT 6
Unshielded twisted pair (UTP)
Solid
Length
304.9 m
Grey
Package Type
Bulk
Network Cable Type
Bulk cable - CAT 6
Jacket Material
PVC
American Wire Gauge (AWG)
23
Solid
Length
304.9 m
Grey
UL, RoHS - up to 500 MHz
Package Type
Bulk
91F7 StarTech.com Cat 6 RJ45 Keystone Jack Network Coupler - F/F In Stock £7.40
91F7 StarTech.com Solid Wire Cat 6 Modular Plug In Stock £15.47
Length: 304.9m
Colour: Grey
