StarTech.com Privacy Screen Adhesive Strips
Quicklinx: GVKYWS00 Mfr#: MON-PRIVACY-SCREEN-K
Device Type: Laptop, Monitor
Type: [N/A]
Device Screen Size: [N/A]
Colour: Clear
More than 50 In Stock
£5.85 ex VAT
£7.02 inc VAT
The MON-PRIVACY-SCREEN-K is a kit for installing/replacing privacy filter hardware. This kit also enables the reuse of existing privacy filters, allowing you to use a privacy filter with multiple displays of the same size.
  • Replace Lost or Damaged Mounting Hardware
    The privacy screen installation kit includes an eight-piece adhesive bezel tab set (two large and six small), a twelve-piece adhesive strip set (six short and six long), and a wiping cloth. Use the mounting tabs for non-permanent installations, with the ability to quicky remove and reuse privacy screens for multiple monitors of the same size, or switch between matte and glossy sides of a privacy filter. The adhesive strips are for semi-permanent installations. The strips can be removed without leaving behind any adhesive residue.
  • Compatibility
    The universal installation kit is compatible with StarTech.com's privacy filters, such as PRIVSCNMONxx, PRIVACY-SCREEN-xxM, and PRIVACY-SCREEN-xxMB, as well as third-party privacy filters. The installation kit can be used for monitors of up to 32 inches; larger displays may require additional kits. The MON-PRIVACY-SCREEN-K is TAA compliant and backed for 2-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com Privacy Screen Adhesive Strips and Mounting Tabs, Installation Kit for Laptop/Computer Monitor Anti Glare Privacy Filters, Replacement Strips and Holder Tabs - Anti Glare Screen Holder Tabs (MON-PRIVACY-SCREEN-K) - display privacy filter mounting kit
Display privacy filter mounting kit
Package Content
Wiping cloth, 6 large adhesive strips, 6 small adhesive strips, 2 large mounting tabs, 6 small mounting tabs
Clear
Product Material
Plastic
8.3 cm x 10.3 cm
16 g
Product Material
Plastic
Package Content
8.3 cm
10.3 cm
Thickness
1 mm
16 g
23 cm x 11 cm x 0.2 cm / 26 g
Clear
Limited warranty: - 2 years
GVKY StarTech.com 13.3in Laptop Privacy Screen In Stock £9.02
GVKY StarTech.com 14in Laptop Privacy Screen In Stock £29.56
Device Type: Laptop
Device Type: Monitor
Type: [N/A]
Colour: Clear
