StarTech.com 13.3in Laptop Privacy Screen
Quicklinx: HDFSWS00 Mfr#: 133L-PRIVACY-SCREEN
Device Type: Notebook
Type: Privacy Screen
Device Screen Size: 13.3
Colour: Transparent
13 In Stock
£33.56 ex VAT
£40.27 inc VAT
This laptop privacy screen features a universal design, compatible with 13.3" laptops with a 16:9 aspect ratio.
  • Prevent visual eavesdropping
    This privacy filter is a convenient and cost-effective solution to protect your confidential data from unwanted viewers. The privacy shield darkens your laptop screen from the sides while providing a clear viewing angle of +/-30 degrees, offering a total visible area of 60 degrees.
  • Reversible Filter
    The privacy screen protector is reversible, with an anti-glare matte side for environments prone to glare and a high-gloss side that helps retain color vibrancy. The matte side provides additional screen protection with a fingerprint-resistant coating.
  • Hassle-free Installation
    The universal design won't interfere with top-mounted webcams, sensors, or when closing the lid. The privacy screen can be installed in two different ways. Affix the privacy screen shield to bezel-less displays using the transparent and residue-free adhesive strips. Alternatively, use the slide mount tabs to install the privacy screen on displays with bezels. The latter is recommended when frequent reversal or removal is required.
  • Blue Light Reduction
    Reduce eye strain and improve visual comfort with this blue light reducing privacy shield. It blocks 40% - 51% of the blue light emitted from the display in the 380nm - 480nm wavelength range. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision. This TAA-compliant laptop privacy filter is backed for two years, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 13.3in Laptop Privacy Screen, Anti-Glare Privacy Filter for Widescreen (16:9) Displays, Laptop Monitor Screen Protector with 51% Blue Light Reduction - Reversible Matte/Glossy Sides (133L-PRIVACY-SCREEN) - notebook privacy filter (horizontal)
Notebook privacy filter (horizontal)
Installation Type
Removable
Package Content
Wiping cloth, 1 set of adhesive strips, 1 set of slide mount tabs
Transparent
Product Material
Plastic
29.4 cm 16.6 cm
90 g
Display Screen Size Compatibility
13.3"
Reversible anti-glare, reversible, 51% blue light reduction
Product Material
Plastic
Package Content
29.4 cm
16.6 cm
Thickness
0.5 mm
90 g
38.5 cm x 26 cm x 0.2 cm / 150 g
13.3"
Reversible
Transparent
Display Filter
Installation Type
Removable
Aspect Ratio
16:9
Anti-glare, reversible, 51% blue light reduction
TAA Compliant
Limited warranty: - 2 years
HDFS StarTech.com 14in Laptop Privacy Screen In Stock £32.09
HDFS StarTech.com 14in MacBook Privacy Screen In Stock £32.40
HDFS StarTech.com 16in MacBook Privacy Screen In Stock £31.29
HDFS StarTech.com 13.5in Laptop Privacy Screen In Stock £31.15
HDFS StarTech.com 15.6" Laptop Privacy Filter In Stock £32.59
HDFS StarTech.com 17.3" Laptop Privacy Filter In Stock £33.15
HDFS StarTech.com 14in MacBook Privacy Screen In Stock £32.46
HDFS StarTech.com 14in Laptop Privacy Screen In Stock £31.15
HDFS StarTech.com 15.6in Laptop Privacy Screen In Stock £27.75
HDFS StarTech.com 16in MacBook Privacy Screen In Stock £32.66
Colour: Transparent
