This PCI based Powered USB Adapter Card adds three Powered USB (USB PlusPower) ports to any computer, through an available PCI Slot.
Drawing power from either the PCI slot or the computer power supply, the Powered USB adapter card provides up to 3A of current to each connected device, allowing for up to three Powered USB devices to be installed at a time.
Plus, this PCI Powered USB Adapter Card can be connected to StarTech.com's 2 Port 12V/24V Powered USB Adapter Card (PUSBADAP), to create two additional Powered USB ports, without using an extra PCI slot.
- StarTech.com 3 Port PCI 12V Powered USB Adapter Card - USB Plus Power - USB adapter - PCI - USB 2.0 x 3
- USB adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI
- Bus Voltage
- Universal (3.3 V & 5.0 V)
- Ports
- USB 2.0 x 3
- 8.1 cm x 6.7 cm
- 200 g
- Data Link Protocol
- USB, USB 2.0
- Data Transfer Rate
- 480 Mbps
- Processor
- 1 x NEC µPD720101GJ
- System Requirements
- Microsoft Windows 2003, Microsoft Windows 2000 / ME / XP/ Vista
- Limited lifetime warranty
- Designed For
- P/N: PUSBDYB24V06, PUSBDYB24V10, PUSBDYB24V03
- USB adapter
- Form Factor
- Plug-in card
- PCI
- Bus Voltage
- Ports
- USB 2.0 x 3
- Connectivity Technology
- Wired
- USB, USB 2.0
- 480 Mbps
Processor / Memory
- Processor
- 3 x USB 2.0 - 8 pin USB PlusPower (12 V)
- Compatible Slots
- 1 x PCI
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 8.1 cm
- 6.7 cm
- 200 g
- Limited warranty - lifetime
- Designed For
- StarTech.com 24V to Hosiden+USB B Powered USB Cable
